You must also have a separate Vantage.vtg (say VantageC.vtg for Citrix),
that properly reflects the local working directory in the vtg file. An
example of our Citrix startup file:
[Vantage Startup]
Executable=V:\PROGRESS\bin\prowin32.exe
Database=V:\Vantage\db\vantage
IniFile=V:\Vantage\vantage.ini
ParameterFile=V:\Vantage\db\Vantage.pf
ConnectOptions=-N TCP -H pcsdbsrv -S vantage
TempDirectory=w:\Vntgwork
StartupProcedure=mainmenu.w
OtherParameters=-rand 2 -q -basekey ini
Hope this helps,
Rick Lane
Intelligent Systems Integration, Inc.
661 B Weber Drive
Wadsworth, OH 44281
Phone: 330-335-5291
"Helping Business Make Intelligent Use of Technology"
Sent: Friday, May 11, 2001 5:10 PM
To: Vantage Onelist (E-mail)
Subject: [Vantage] Citrix & Vantage ver4
I need some help to save my sanity...if I have any.
I have my Citrix clients set up and used the instructions to set up the
seperate vntgwork files per user.
I have my volume is N:\users\the user's login\vntgwork
My map is working x: servername\users\%username%
If I have a setting in Vantage.ini
LocalWorkDir=n:\users\%username%\Vntgwork or x:\vntgwork
they can not use vantage. with the mapped drive it says they don't have
rights to the drive.
and the whole path doesn't work either.
Can you tell what I am doing wrong?
Thanks so much
Nancy Dunn
Winco Ind. Inc.
[Vantage Startup]
Hope this helps,
Rick Lane
661 B Weber Drive
Wadsworth, OH 44281
Phone: 330-335-5291
Thanks so much
Nancy Dunn
Winco Ind. Inc.
