Choosing Customization for Conext Pop-Up (Right Click) (Version
To make context menu changes global, you need to select the customisation checkbox, then search for your process reference and create your custom context item.
Process calling maintenance doesn't seem to make any difference in this utility.
--- In vantage@yahoogroups.com, Jose Gomez <jose@...> wrote:
> In that case you want Process Calling Maintenance where you can specify the
> called menu as well as the caller form example
> Called Form: So Entry
> Call: Customer Shipment Entry
> *Jose C Gomez*
> *Software Engineer*
> *T: 904.469.1524 mobile
> E: jose@...
> http://www.josecgomez.com
> <http://www.linkedin.com/in/josecgomez> <http://www.facebook.com/josegomez>
> <http://www.google.com/profiles/jose.gomez> <http://www.twitter.com/joc85>
> <http://www.josecgomez.com/professional-resume/>
> <http://www.josecgomez.com/feed/>
> <http://www.usdoingstuff.com>
> *Quis custodiet ipsos custodes?*
> On Tue, Oct 16, 2012 at 8:44 AM, Anon
> <epicor-team@...>wrote:
> > As far as I can recall the context menu maintenance changes are global.
> > There isn't a context menu for any single customization it's either a
> > personalization for your account or a customization for all.
> > --- In vantage@yahoogroups.com, Jose Gomez <jose@> wrote:
> > > Context Calling Maintenance.
> > > *Jose C Gomez*
> > > *Software Engineer*
> > > E: jose@
> > > On Tue, Oct 16, 2012 at 8:18 AM, c.krusen1 <ckrusen1@> wrote:
> > > > How do you specify which customization is used when some right-clicks
> > in a
> > > > context sensative field (The ones with the blue triangle in the
> > upper-right
> > > > corner)?
> > > > The sales folks need to use customization 'A', while Materials people
> > can
> > > > use the original.
> > > > Calvin
How do you specify which customization is used when some right-clicks in a context sensative field (The ones with the blue triangle in the upper-right corner)?
The sales folks need to use customization 'A', while Materials people can use the original.
Calvin
*Jose C Gomez*
*Software Engineer*
E: jose@...
> corner)?
> use the original.
> Calvin
As far as I can recall the context menu maintenance changes are global. There isn't a context menu for any single customization it's either a personalization for your account or a customization for all.
> *Jose C Gomez*
> *Software Engineer*
> E: jose@...
> > corner)?
> > use the original.
> > Calvin
*Jose C Gomez*
*Software Engineer*
E: jose@...
> > *Jose C Gomez*
> > *Software Engineer*
> > E: jose@...
> in a
> upper-right
> > > corner)?
> can
> > > use the original.
> > > Calvin
