We are in the process of moving from E9 to 10. In our engineering workbench, we are using UD05 as a child table to ECORev. We have user codes tied to some UD05.Fields in EpiCombos.
I am not able to figure out how to work around Errors in the form : “Error accessing the database: Invalid column name XXXX”
It’s been a long time since we set it up in E9. Maybe I’m missing some steps, but I’ve verified that the epiCombo properties look correct and I’ve also been able to get User Codes working in an epiCombo that points at a standard table’s ud field.
It seems like I have something misconfigured in the setup of the child UD table. Any ideas would be appreciated!
Joe
Here is the error detail:
Server Side Exception
Error accessing the database: Invalid column name ‘ECO_OpenPO’.
Error Detail
Description: Error accessing the database: Invalid column name ‘ECO_OpenPO’.
Program: System.Data.dll
Method: OnError
Original Exception Type: SqlException
SQL Line Number: 7
SQL Error Number: 207
Framework Method: b__0
Framework Line Number: 488
Framework Column Number: 36
Framework Source: b__0 at offset 1280 in file:line:column c:_Releases\ICE\3.1.600.0\Source\Framework\Epicor.Ice\Services\TablesetBound.cs:488:36
Server Trace Stack: at System.Data.SqlClient.SqlConnection.OnError(SqlException exception, Boolean breakConnection, Action1 wrapCloseInAction) at System.Data.SqlClient.TdsParser.ThrowExceptionAndWarning(TdsParserStateObject stateObj, Boolean callerHasConnectionLock, Boolean asyncClose) at System.Data.SqlClient.TdsParser.TryRun(RunBehavior runBehavior, SqlCommand cmdHandler, SqlDataReader dataStream, BulkCopySimpleResultSet bulkCopyHandler, TdsParserStateObject stateObj, Boolean& dataReady) at System.Data.SqlClient.SqlDataReader.TrySetMetaData(_SqlMetaDataSet metaData, Boolean moreInfo) at System.Data.SqlClient.TdsParser.TryRun(RunBehavior runBehavior, SqlCommand cmdHandler, SqlDataReader dataStream, BulkCopySimpleResultSet bulkCopyHandler, TdsParserStateObject stateObj, Boolean& dataReady) at System.Data.SqlClient.SqlDataReader.TryConsumeMetaData() at System.Data.SqlClient.SqlDataReader.get_MetaData() at System.Data.SqlClient.SqlCommand.FinishExecuteReader(SqlDataReader ds, RunBehavior runBehavior, String resetOptionsString, Boolean isInternal, Boolean forDescribeParameterEncryption) at System.Data.SqlClient.SqlCommand.RunExecuteReaderTds(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream, Boolean async, Int32 timeout, Task& task, Boolean asyncWrite, Boolean inRetry, SqlDataReader ds, Boolean describeParameterEncryptionRequest) at System.Data.SqlClient.SqlCommand.RunExecuteReader(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream, String method, TaskCompletionSource
1 completion, Int32 timeout, Task& task, Boolean& usedCache, Boolean asyncWrite, Boolean inRetry)
at System.Data.SqlClient.SqlCommand.RunExecuteReader(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream, String method)
at System.Data.SqlClient.SqlCommand.ExecuteReader(CommandBehavior behavior, String method)
at System.Data.SqlClient.SqlCommand.ExecuteReader()
at Ice.TablesetBound`3.<>c__DisplayClass27_0.b__0() in c:_Releases\ICE\3.1.600.0\Source\Framework\Epicor.Ice\Services\TablesetBound.cs:line 488
Client Stack Trace
at Epicor.ServiceModel.Channels.ImplBase`1.ShouldRethrowNonRetryableException(Exception ex, DataSet[] dataSets)
at Ice.Proxy.Lib.BOReaderImpl.GetList(String serviceNamespace, String whereClause, String columnList)
at Ice.Lib.Framework.EpiCombo.getDataSet()
Inner Exception
