I need to take Epicor down for maintenance. I’ve sent out emails detailing the down time, etc. but I have a feeling some users will still end up being in Epicor when I go to take it down.
Is there a way for me to check to see who’s in Epicor before I turn it off?
You can look at either User Tracker under System Management (may be in another menu, but I don’t have Epicor open in front of me). You can also look in the Epicor Admin Console under Sessions. Both will show active user sessions.
That’s possible. We upgraded from Epicor 9 to 10.1.600 and then fairly quickly to 10.2.300, so I’m not sure what version it was added in. You should still be able to use the Epicor Admin Console to view active sessions none the less.
