Hi Experts.
I have loaded a checkbox on a form and it is always disabled when the form gets loaded.
It is bound to a new ud field. Everything is enabled, no Read only.
Is there something I am missing?
Hi Experts.
Do any other UD fields show as editable? Or is that the only field from the UD table in your form?
Hi and thanks.
I have this on a PO form and I think once you approve the PO all fields are locked, even checkboxes added by users.
When I un-approve the PO I can use the checkbox.
The checkbox is to mark PO’s as shipped from the supplier.
I don’t have any UD fields on my POHeader, so run a test for me.
Add a button to your form.
private void epiButtonC1_Click(object sender, System.EventArgs args)
EpiDataView edvPOHeader = (EpiDataView)(oTrans.EpiDataViews["POHeader"]);
edvPOHeader.dataView[edvPOHeader.Row]["YourCustomField_c"] = true; //false?
And see if it will save.
If it does, you can unbind that checkbox and control it yourself.
Something like this perhaps:
epiCheckBoxC1.ReadOnly = true;
//Populate Value on load
private void edvPOHeader_EpiViewNotification(EpiDataView view, EpiNotifyArgs args)
if ((args.NotifyType == EpiTransaction.NotifyType.Initialize))
if ((args.Row > -1))
epiCheckBoxC1.ReadOnly = false;
epiCheckBoxC1.Checked = (bool)edvPOHeader.dataView[edvPOHeader.Row]["YourCustomField_c"];
else
epiCheckBoxC1.Checked = false;
//Set before save
private void oTrans_poAdapter_BeforeAdapterMethod(object sender, BeforeAdapterMethodArgs args)
switch (args.MethodName)
case "Update":
edvPOHeader.dataView[edvPOHeader.Row]["YourCustomField_c"] = epiCheckBoxC1.Checked;
break;
Thanks for your help.
I will give it try and let you know.
Hi Kevin
Sorry for the delay.
This did not work.
If you add a button, as soon as the PO is approved the button is disabled.
Not sure what to try next.
Steve
