Checkbox Read Only
How do you make a rule that would make a checkbox read only after its been checked. Would this be rule wizard or event? Every time i try and make a rule for it in customization it doesnt work.
Assuming the checkbox is bound to a field you can use a Row Rule. Here is example
that is how I did it before, but it wont lock after I check it2017-11-08_10-53-59.pdf (31.6 KB)
Odd. That definitely looks correct. I assume the checkbox on your screen has the EpiBinding to FirmReleaseAll_c?
Can you paste the code from the script editor just to see if perhaps something is off?
yes that is correct
// Custom code for SalesOrderForm
// Created: 10/28/2016 9:01:16 AM
using System;
using System.ComponentModel;
using System.Data;
using System.Diagnostics;
using System.Windows.Forms;
using Erp.Adapters;
using Erp.UI;
using Ice.Lib;
using Ice.Adapters;
using Ice.Lib.Customization;
using Ice.Lib.ExtendedProps;
using Ice.Lib.Framework;
using Ice.Lib.Searches;
using Ice.UI.FormFunctions;
public class Script
// ** Wizard Insert Location - Do Not Remove ā€˜Begin/End Wizard Added Module Level Variablesā€™ Comments! **
CreateRowRuleOrderHedFirmReleaseAll_cEquals_true();;;
	SetExtendedProperties();
	// Begin Custom Code Disposal
	// End Custom Code Disposal
private void SetExtendedProperties()
	// Begin Wizard Added EpiDataView Initialization
	EpiDataView edvOrderDtl = ((EpiDataView)(this.oTrans.EpiDataViews["OrderDtl"]));
	EpiDataView edvOrderHed = ((EpiDataView)(this.oTrans.EpiDataViews["OrderHed"]));
	// End Wizard Added EpiDataView Initialization
	// Begin Wizard Added Conditional Block
	if (edvOrderDtl.dataView.Table.Columns.Contains("DocUnitPrice"))
		// Begin Wizard Added ExtendedProperty Settings: edvOrderDtl-DocUnitPrice
		edvOrderDtl.dataView.Table.Columns["DocUnitPrice"].ExtendedProperties["Enabled"] = true;
		edvOrderDtl.dataView.Table.Columns["DocUnitPrice"].ExtendedProperties["Format"] = "999,999.99";
		// End Wizard Added ExtendedProperty Settings: edvOrderDtl-DocUnitPrice
	if (edvOrderHed.dataView.Table.Columns.Contains("OrderType_c"))
		// Begin Wizard Added ExtendedProperty Settings: edvOrderHed-OrderType_c
		edvOrderHed.dataView.Table.Columns["OrderType_c"].ExtendedProperties["Enabled"] = true;
		// End Wizard Added ExtendedProperty Settings: edvOrderHed-OrderType_c
	if (edvOrderDtl.dataView.Table.Columns.Contains("DocListPrice"))
		// Begin Wizard Added ExtendedProperty Settings: edvOrderDtl-DocListPrice
		edvOrderDtl.dataView.Table.Columns["DocListPrice"].ExtendedProperties["Format"] = ">>>.>>9.99";
		// End Wizard Added ExtendedProperty Settings: edvOrderDtl-DocListPrice
	// End Wizard Added Conditional Block
private void CreateRowRuleOrderHedFirmReleaseAll_cEquals_true()
	// Description: LockFirmReleaseAll
	// **** begin autogenerated code ****
	RuleAction disabledOrderHed_FirmReleaseAll_c = RuleAction.AddControlSettings(this.oTrans, "OrderHed.FirmReleaseAll_c", SettingStyle.Disabled);
	RuleAction[] ruleActions = new RuleAction[] {
			disabledOrderHed_FirmReleaseAll_c};
	// Create RowRule and add to the EpiDataView.
	RowRule rrCreateRowRuleOrderHedFirmReleaseAll_cEquals_true = new RowRule("OrderHed.FirmReleaseAll_c", RuleCondition.Equals, true, ruleActions);
	((EpiDataView)(this.oTrans.EpiDataViews["OrderHed"])).AddRowRule(rrCreateRowRuleOrderHedFirmReleaseAll_cEquals_true);
	// **** end autogenerated code ****
Iā€™m running into similar issues. Checkbox control not recognized by a rule setting. Also canā€™t affect it with ExtendedProperties on the dataview column or changing an unbound checkbox control. Very annoying.
I got it to work on custom fields. Here is the code from the Customization screen.
Oh, and the proper extended property is ā€œRead Onlyā€ not ā€œEnabledā€. That tripped me up when I was trying to do it too.
		this.epiCheckBoxC1.CheckStateChanged += new System.EventHandler(this.epiCheckBoxC1_CheckStateChanged);
		this.epiCheckBoxC2.CheckStateChanged += new System.EventHandler(this.epiCheckBoxC2_CheckStateChanged);
		this.epiCheckBoxC1.CheckStateChanged -= new System.EventHandler(this.epiCheckBoxC1_CheckStateChanged);
		this.epiCheckBoxC2.CheckStateChanged -= new System.EventHandler(this.epiCheckBoxC2_CheckStateChanged);
	private void epiCheckBoxC1_CheckStateChanged(object sender, System.EventArgs args)
		if (epiCheckBoxC1.Checked = true)
			//private void SetExtendedProperties()
				EpiDataView edvPart = ((EpiDataView)(this.oTrans.EpiDataViews["Part"]));
				if (edvPart.dataView.Table.Columns.Contains("NPI_c"))
				// Begin Wizard Added ExtendedProperty Settings: edvPart-NPI_c
					edvPart.dataView.Table.Columns["NPI_c"].ExtendedProperties["Read Only"] = true;
				// End Wizard Added ExtendedProperty Settings: edvPart-NPI_c
Hi,
Iā€™m trying to do a similar thing on the order page with a UD checkbox but for some reason nothing is happening. The field does not become read only after itā€™s checked. Is there something Iā€™m missing?
This is the code I used.
// ** Wizard Insert Location - Do not delete ā€˜Begin/End Wizard Added Variable Initializationā€™ lines **
	this.chkWarranty.CheckStateChanged += new System.EventHandler(this.chkWarranty_CheckStateChanged);
	this.chkWarranty.CheckStateChanged -= new System.EventHandler(this.chkWarranty_CheckStateChanged);
private void chkWarranty_CheckStateChanged(object sender, System.EventArgs args)
	if (chkWarranty.Checked = true)
			if (edvOrderHed.dataView.Table.Columns.Contains("Warranty_c"))
				//Begin Wizard Added ExtendedProperty
					edvOrderHed.dataView.Table.Columns["Warranty_c"].ExtendedProperties["ReadOnly"] = true;
I managed to get this working using the Row rule. :slight_smile:
thanks
