Changing Vantage userforms (Pack Slip ...Etc) with Crystal Odb
Try creating a formula against the string field in the DBF
ToNumber(PoNum)
The reason you wouldn't want to link based on a ToText of the Ponum in the
Live Database, is that that formula would have to be evaluated for every po
entry in the database. Creating the formula based on the single (or at
least fewer) entries in the DBF would be the better choice.
However, linking based on a formula can create performance issues, and this
one might as well.
Hope this helps,
Thaddeus
<original msg>
Thad,
I gave this a quick shot, Its a no go because the dbf files have been
formated differently. For example, The PO number in the regular database
is
a numeric format, the exported PO has been converted to Alpha. The links
wont link with out going through some conversion.
Shirley
Sent: Thursday, June 14, 2001 12:04 PM
To: 'vantage@yahoogroups.com'
Subject: RE: [Vantage] Changing Vantage userforms (Pack Slip ...Etc)
with
Crystal Odbc forms.
You probably want to keep the master table based on the DBF export,
which
contains only one record, then link it to the ODBC connection for the
fields
not contained in the DBF using CompanyID, and Packing Slip Number.
Otherwise you have to prompt the user for the packing slip number using
a
parameter field
Of course, linking the DBD and ODBC will limit you to an inner join, but
I
believe that is not a problem in this case
Let me know if this works for you or not.
Best Regards,
Thaddeus Jacobs
Assistant LAN Technologist / Vantage Support
Kinematic Automation, Inc
mailto:tjacobs@...
Sent: Thursday, June 14, 2001 10:49 AM
with Crystal Odbc forms.
I'm replacing the form in a major way. We are loosing a clerical person
who
did an assortment of documents related to shipping, and I've been
"requested" to automate those functions, additionally we have some
(major)
customers that demand their paperwork in a special way. IE: All
shipments
on one packing list regardless of different P.O.s, and a separate cert
document for each LOT number. I've got a Crystal form using the current
dbf
files that will produce a Cert if the appropriate VB forms checkboxes
are
checked and the right VB forms edit fields are filled in. But I need to
go
further with this. I have a couple of ideas if its not possible to
establish "CURRENT RECORD", a button in the VB forms area of the Packing
Slip header, or a compiled report in the Favorites area. Im just hoping
to
use the regular print button in the packing slip.
Shirley H. Graver
6597 West 130th St
Parma Heights, OH 44130
Sent: Thursday, June 14, 2001 11:38 AM
Subject: Re: [Vantage] Changing Vantage userforms (Pack Slip ...Etc)
with
Crystal Odbc forms.
Are you needing just one or two extra fields, or are you replacing the
whole form in major ways?
I have modified existing Userform reports by adding to the canned one
with
ODBC. I don't have any idea how to grab the data on the screen for a
report.
Troy
----- Original Message -----
Sent: Thursday, June 14, 2001 11:22 AM
Subject: [Vantage] Changing Vantage userforms (Pack Slip ...Etc)
with
Crystal Odbc forms.
I've searched the archives, with no luck. I need to replace the
existing
Packing Slip form with one written in ODBC. What I'm looking for is
how
to
establish with the ODBC form to ONLY print the current record on the
screen.
The functions that I've gone through are'nt clear about how this is
done. I
certain someone has replaced the canned forms with their own. I
would
much
appreciate the help.
Shirley Graver
(End User)
Sys Admin
Rubber associates Inc.
Cleveland/Akron
Yahoo! Groups Sponsor
To access the Files Section of our Yahoo!Group for Report Builder
and
Crystal Reports and other 'goodies', please go to:
http://groups.yahoo.com/group/vantage/files/. Note: You must have
already
linked your email address to a yahoo id to enable access.
Select a
categorySpecialty-TechnologySpecialty-FinancialForeign StockLarge
GrowthMid-Cap BlendSmall Value
To access the Files Section of our Yahoo!Group for Report Builder and
already
already
http://docs.yahoo.com/info/terms/
www.
already
http://groups.yahoo.com/group/vantage/files/. Note: You must have already
You probably want to keep the master table based on the DBF export, which
contains only one record, then link it to the ODBC connection for the fields
Otherwise you have to prompt the user for the packing slip number using a
parameter field
Of course, linking the DBD and ODBC will limit you to an inner join, but I
Best Regards,
Thaddeus Jacobs
mailto:tjacobs@...
I'm replacing the form in a major way. We are loosing a clerical person who
"requested" to automate those functions, additionally we have some (major)
customers that demand their paperwork in a special way. IE: All shipments
document for each LOT number. I've got a Crystal form using the current dbf
files that will produce a Cert if the appropriate VB forms checkboxes are
checked and the right VB forms edit fields are filled in. But I need to go
Slip header, or a compiled report in the Favorites area. Im just hoping to
Shirley H. Graver
6597 West 130th St
Subject: Re: [Vantage] Changing Vantage userforms (Pack Slip ...Etc) with
Crystal Odbc forms.
I have modified existing Userform reports by adding to the canned one with
report.
Troy
Subject: [Vantage] Changing Vantage userforms (Pack Slip ...Etc) with
Crystal Odbc forms.
existing
Packing Slip form with one written in ODBC. What I'm looking for is how
to
screen.
done. I
certain someone has replaced the canned forms with their own. I would
much
Shirley Graver
(End User)
Sys Admin
Cleveland/Akron
Select a
Thad,
formated differently. For example, The PO number in the regular database is
Shirley
Subject: RE: [Vantage] Changing Vantage userforms (Pack Slip ...Etc) with
Crystal Odbc forms.
fields
parameter field
Best Regards,
Thaddeus Jacobs
mailto:tjacobs@...
who
dbf
go
to
Shirley H. Graver
6597 West 130th St
with
Crystal Odbc forms.
with
report.
Troy
Crystal Odbc forms.
existing
how
to
screen.
done. I
much
Shirley Graver
(End User)
Sys Admin
Cleveland/Akron
already
Select a
already
already
www.
You CAN link a text field to a numeric field through a subreport. If a subreport would work in this case, give me a holler.
Troy
Sent: Thursday, June 14, 2001 12:16 PM
Subject: RE: [Vantage] Changing Vantage userforms (Pack Slip ...Etc) with Crystal Odbc forms.
Thad,
Shirley
Crystal Odbc forms.
fields
parameter field
Best Regards,
Thaddeus Jacobs
mailto:tjacobs@...
who
dbf
go
to
Shirley H. Graver
6597 West 130th St
with
Crystal Odbc forms.
with
report.
Troy
Crystal Odbc forms.
existing
how
to
screen.
done. I
much
Shirley Graver
(End User)
Sys Admin
Cleveland/Akron
already
Select a
already
already
www.
To access the Files Section of our Yahoo!Group for Report Builder and Crystal Reports and other 'goodies', please go to: http://groups.yahoo.com/group/vantage/files/. Note: You must have already linked your email address to a yahoo id to enable access.
