Changing Vantage Colors
Is there a way to do a global change on that in the vantage.ini file?
Sent: Friday, January 16, 2004 1:22 PM
Subject: [Vantage] Re: Changing Vantage Colors
Along with changing the company name on the test database you can
change on each machine the favorites background color. Just right
click in the favorites area and go to properties and change the color.
-- In vantage@yahoogroups.com, Todd Anderson <tanderson@j...> wrote:
> Jasper,
> Can't help you on that but what I ended up doing was changing the
company
> name in the test database.
> Something like "******* TEST DATABASE ******" ...
> The company name shows in the title bar.
> Todd
> From: Jasper Recto [mailto:jrecto@l...]
> Sent: Friday, January 16, 2004 8:16 AM
> To: Vantage Groups (E-mail)
> Subject: [Vantage] Changing Vantage Colors
> Good morning all,
> Is there a way to change the default colors of the menu bar and
favorites
> bar for EVERY user? I want our test database to have a specific
color so
> people won't confuse which database they are in.
> Thanks,
> Jasper
must have
Builder and
> <http://groups.yahoo.com/group/vantage/files/.>
> <http://groups.yahoo.com/group/vantage/messages>
> <http://groups.yahoo.com/group/vantage/links>
> _____
> Yahoo! Groups Links
> * To visit your group on the web, go to:
> <http://groups.yahoo.com/group/vantage/>
> * To unsubscribe from this group, send an email to:
> vantage-unsubscribe@yahoogroups.com
> <mailto:vantage-unsubscribe@yahoogroups.com?subject=Unsubscribe>
> * Your use of Yahoo! Groups is subject to the Yahoo! Terms of
Service
> <http://docs.yahoo.com/info/terms/> .
Yahoo! Groups Links
Your use of Yahoo! Groups is subject to:
Good morning all,
Is there a way to change the default colors of the menu bar and favorites bar for EVERY user? I want our test database to have a specific color so people won't confuse which database they are in.
Jasper
Jasper,
Can't help you on that but what I ended up doing was changing the company
Todd
Good morning all,
Jasper
_____
Yahoo! Groups Links
* Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service
Thanks! I give that a go.
Jasper
Sent: Friday, January 16, 2004 9:20 AM
Subject: RE: [Vantage] Changing Vantage Colors
Jasper,
Todd
Good morning all,
Jasper
_____
Yahoo! Groups Links
Yahoo! Groups Links
The easy way I did it was: go to menu structure maint. and change the name
vantage to ----TRAINING-VANTAGE and I changed the live one to VANTAGE-LIVE
Judd
Custom Hoists, Inc.
Ph: (419) 368-4721 EXT. 246
Sent: Friday, January 16, 2004 9:16 AM
Good morning all,
Jasper
_____
Yahoo! Groups Links
This is WAY out on a limb but since it is a test database anyway....
The table UserFile has settings for each user's color preferences in that database. You (or someone a lot more skilled at this than me anyway) might be able to make some sort of .p routine to spin thru all the users and set the four color codes to the same value. You might have to periodically run if users are prone to making changes or run once after each refresh of the test database. I suspect you could refresh the test database, log in to it and then run the .p from the command window and change that particular DB. Or then again maybe I am way off base ont his.
Just an idea anyway.
-Todd C.
PS - If that someone "more skilled than I" can really do such a .p routine I would love to have a copy. Probably a good candidate for the download area.
Good morning all,
Jasper
_____
Yahoo! Groups Links
vantage-unsubscribe@yahoogroups.com <mailto:vantage-unsubscribe@yahoogroups.com?subject=Unsubscribe>
* Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service <http://docs.yahoo.com/info/terms/> .
A method I use is copying the "Vantage.ini" file and give it your test
database name, and point to it in your "test.vtg" file instead of
"vantage.ini" in line 4. When you open the ini file for editing, it advises
you against changing the first 15 colors (and I haven't tried changing those
yet), but I've modified some of 16 through 31 as follows (trial and error
using windows color codes for "red,green,blue"):
color16=0,0,255
color17=164,200,240
color18=255,0,255
color19=255,255,255
color20=255,255,255
color21=255,0,0
color22=0,255,255
color23=0,0,0
color24=0,255,0
color25=0,128,192
color26=0,0,255
color27=255,0,255
color28=255,255,0
color29=255,0,0
color30=255,255,255
color31=255,255,0
These changes so far ony make the input fields white text on a red
background. Also, when you open the test database, select "default colors"
in the "options, change colors" pull down menu.
Norm Watkins
Engineering Mgr.
ELECPAC
847-639-2307
Good morning all,
Jasper
Yahoo! Groups Links
Just tested this and it does work. Seems I can change the settings to the
userfile outside of Vantage and have them take effect next time I log it.
Also there is the setting to lock the users so that they can't change the
settings.
Sent: Friday, January 16, 2004 9:12 AM
-Todd C.
Good morning all,
Jasper
_____
Yahoo! Groups Links
Yahoo! Groups Links
> Jasper,
company
> Todd
> Good morning all,
favorites
color so
> Thanks,
> Jasper
must have
Builder and
> _____
> Yahoo! Groups Links
Service
