Changing the decimal places in Purchase Advisor
We are on E10
Regards
Adrian Lauchlan FRSA
mobile 07852 270968
Sent: 19 May 2015 19:18
Subject: Re: [Vantage] Changing the decimal places in Purchase Advisor
What version of Epicor are you on?  In Epicor 9 you can change some decimal places we have made the changes after setting up.  I can't remember if it is a conversion or if Epicor support sent us a program to run to change the decimal places.
On Tuesday, May 19, 2015 1:52 PM, "'Adrian Lauchlan' adrianlauchlan@... [vantage]" <vantage@yahoogroups.com> wrote:
I have actually referred to the wrong field - given the wrong info by purchasing department. The purchase history shows a Supplier Unit Cost as 68.95 but the Base price in it is showing 69 and no decimal places so we actually want it to show at least 2 decimal places.
I am looking for code to put in to change the masking/formatting
Regards
mobile 07852 270968
Sent: 19 May 2015 17:35
Subject: RE: [Vantage] Changing the decimal places in Purchase Advisor
Unfortunately the decimal place setup is done in the Administration Console when creating a brand new company.
You can place rounding rules on the UOM's in certain E9 or E10 or into the reporting but I don't believe that the ability to limit the decimals exists at the Purchase Advisor or Part Transaction levels.
Sent via the Samsung GALAXY S®4, an AT&T 4G LTE smartphone
-------- Original message --------
From: "adrianlauchlan@... [vantage]" <vantage@yahoogroups.com>
Date: 05/19/2015 11:22 AM (GMT-06:00)
Subject: [Vantage] Changing the decimal places in Purchase Advisor
I want to reduce the decimal places from 5 to 2 in the Purchase History section of the Purchase Advisor. Can anyone suggest how to do this
<div id="ygrps-yiv-1606473076ygrp-text">
  <p></p><p><span>I want to reduce the decimal places from 5 to 2 in the Purchase History section of the Purchase Advisor. Can anyone suggest how to do this</span></p><p></p>
</div>
Regards
mobile 07852 270968
<div id="ygrps-yiv-1108055033yiv0815880311ygrp-text">
  <div></div><div class="ygrps-yiv-1108055033yiv0815880311WordSection1"><div class="ygrps-yiv-1108055033yiv0815880311MsoNormal"><span style="color:rgb(31, 73, 125);font-size:11pt;">I have actually referred to the wrong field - given the wrong info by purchasing department. The purchase history shows a Supplier Unit Cost as 68.95 but the Base price in it is showing 69 and no decimal places so we actually want it to show at least 2 decimal places.</span></div><div class="ygrps-yiv-1108055033yiv0815880311MsoNormal"><span style="color:rgb(31, 73, 125);font-size:11pt;"> &nbsp;</span></div><div class="ygrps-yiv-1108055033yiv0815880311MsoNormal"><span style="color:rgb(31, 73, 125);font-size:11pt;">I am looking for code to put in to change the masking/formatting</span></div><div class="ygrps-yiv-1108055033yiv0815880311MsoNormal"><span style="color:rgb(31, 73, 125);font-size:11pt;"> &nbsp;</span></div><div><div class="ygrps-yiv-1108055033yiv0815880311MsoNormal"><span style="color:rgb(31, 73, 125);font-size:11pt;">Regards</span><span style="color:rgb(31, 73, 125);font-size:11pt;"></span></div><div class="ygrps-yiv-1108055033yiv0815880311MsoNormal"><span style="color:rgb(31, 73, 125);font-size:11pt;">&nbsp;</span><span style="color:rgb(31, 73, 125);font-size:11pt;"></span></div><div class="ygrps-yiv-1108055033yiv0815880311MsoNormal"><span style="color:rgb(31, 73, 125);font-size:11pt;">Adrian Lauchlan FRSA</span><span style="color:rgb(31, 73, 125);font-size:11pt;"></span></div><div class="ygrps-yiv-1108055033yiv0815880311MsoNormal"><span style="color:rgb(31, 73, 125);font-size:11pt;">&nbsp;</span><span style="color:rgb(31, 73, 125);font-size:11pt;"></span></div><div class="ygrps-yiv-1108055033yiv0815880311MsoNormal"><span style="color:rgb(31, 73, 125);font-size:11pt;"> &nbsp;</span></div><div class="ygrps-yiv-1108055033yiv0815880311MsoNormal"><b><span style="color:rgb(31, 73, 125);font-size:11pt;">mobile 07852 270968</span></b><span style="color:rgb(31, 73, 125);font-size:11pt;"></span></div></div><div class="ygrps-yiv-1108055033yiv0815880311MsoNormal"><span style="color:rgb(31, 73, 125);font-size:11pt;"> &nbsp;</span></div><div><div style="padding:3pt 0cm 0cm;border-top-color:rgb(181, 196, 223);border-top-width:1pt;border-top-style:solid;"><div class="ygrps-yiv-1108055033yiv0815880311MsoNormal"><b><span lang="EN-US" style="font-size:10pt;">From:</span></b><span lang="EN-US" style="font-size:10pt;"> vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] <br clear="none"><b>Sent:</b> 19 May 2015 17:35<br clear="none"><b>To:</b> vantage@yahoogroups.com<br clear="none"><b>Subject:</b> RE: [Vantage] Changing the decimal places in Purchase Advisor</span></div></div></div><div class="ygrps-yiv-1108055033yiv0815880311MsoNormal"> &nbsp;</div><div class="ygrps-yiv-1108055033yiv0815880311MsoNormal">&nbsp; </div><div id="ygrps-yiv-1108055033yiv0815880311ygrp-mlmsg"><div id="ygrps-yiv-1108055033yiv0815880311ygrp-msg"><div id="ygrps-yiv-1108055033yiv0815880311ygrp-text"><div><div class="ygrps-yiv-1108055033yiv0815880311MsoNormal">Unfortunately the decimal place setup is done in the Administration Console when creating a brand new company.&nbsp;</div></div><div><div class="ygrps-yiv-1108055033yiv0815880311MsoNormal"> &nbsp;</div></div><div><div class="ygrps-yiv-1108055033yiv0815880311MsoNormal">You can place rounding rules on the UOM&#39;s in certain E9 or E10 or into the reporting but I don&#39;t believe that the ability to limit the decimals exists at the Purchase Advisor or Part Transaction levels.</div></div><div><div class="ygrps-yiv-1108055033yiv0815880311MsoNormal"> &nbsp;</div></div><div><div class="ygrps-yiv-1108055033yiv0815880311MsoNormal"> &nbsp;</div></div><div><div class="ygrps-yiv-1108055033yiv0815880311MsoNormal"> &nbsp;</div></div><div id="ygrps-yiv-1108055033yiv0815880311composer_signature"><div><div class="ygrps-yiv-1108055033yiv0815880311MsoNormal"><span style="color:rgb(87, 87, 87);font-size:10pt;">Sent via the Samsung GALAXY S®4, an AT&amp;T 4G LTE smartphone</span></div></div></div><div class="ygrps-yiv-1108055033yiv0815880311MsoNormal"><br clear="none"><br clear="none">-------- Original message --------<br clear="none">From: &quot;<a rel="nofollow" target="_blank" href="mailto:adrianlauchlan@...%20[vantage]" shape="rect">adrianlauchlan@... [vantage]</a>&quot; &lt;<a rel="nofollow" target="_blank" href="mailto:vantage@yahoogroups.com" shape="rect">vantage@yahoogroups.com</a>&gt; <br clear="none">Date: 05/19/2015 11:22 AM (GMT-06:00) <br clear="none">To: <a rel="nofollow" target="_blank" href="mailto:vantage@yahoogroups.com" shape="rect">vantage@yahoogroups.com</a> <br clear="none">Subject: [Vantage] Changing the decimal places in Purchase Advisor <br clear="none"><br clear="none">&nbsp; </div><div id="ygrps-yiv-1108055033yiv0815880311ygrp-text"><div>I want to reduce the decimal places from 5 to 2 in the Purchase History section of the Purchase Advisor. Can anyone suggest how to do this</div></div></div><div><div class="ygrps-yiv-1108055033yiv0815880311MsoNormal"><span style="color:white;"></span></div></div></div></div></div>
</div>
<div style="height:0px;color:rgb(255, 255, 255);"></div></div>
#ygrps-yiv-1108055033 #ygrps-yiv-1108055033yiv0815880311 #ygrps-yiv-1108055033yiv0815880311 -- #ygrps-yiv-1108055033yiv0815880311ygrp-mkp { border:1px solid #d8d8d8;font-family:Arial;margin:10px 0;padding:0 10px;}
#ygrps-yiv-1108055033 #ygrps-yiv-1108055033yiv0815880311 #ygrps-yiv-1108055033yiv0815880311ygrp-mkp hr {
border:1px solid #d8d8d8;}
#ygrps-yiv-1108055033 #ygrps-yiv-1108055033yiv0815880311 #ygrps-yiv-1108055033yiv0815880311ygrp-mkp #ygrps-yiv-1108055033yiv0815880311hd {
color:#628c2a;font-size:85%;font-weight:700;line-height:122%;margin:10px 0;}
#ygrps-yiv-1108055033 #ygrps-yiv-1108055033yiv0815880311 #ygrps-yiv-1108055033yiv0815880311ygrp-mkp #ygrps-yiv-1108055033yiv0815880311ads {
margin-bottom:10px;}
#ygrps-yiv-1108055033 #ygrps-yiv-1108055033yiv0815880311 #ygrps-yiv-1108055033yiv0815880311ygrp-mkp .ygrps-yiv-1108055033yiv0815880311ad {
padding:0 0;}
#ygrps-yiv-1108055033 #ygrps-yiv-1108055033yiv0815880311 #ygrps-yiv-1108055033yiv0815880311ygrp-mkp .ygrps-yiv-1108055033yiv0815880311ad p {
margin:0;}
#ygrps-yiv-1108055033 #ygrps-yiv-1108055033yiv0815880311 #ygrps-yiv-1108055033yiv0815880311ygrp-mkp .ygrps-yiv-1108055033yiv0815880311ad a {
color:#0000ff;text-decoration:none;}
#ygrps-yiv-1108055033 #ygrps-yiv-1108055033yiv0815880311 #ygrps-yiv-1108055033yiv0815880311ygrp-sponsor #ygrps-yiv-1108055033yiv0815880311ygrp-lc {
font-family:Arial;}
#ygrps-yiv-1108055033 #ygrps-yiv-1108055033yiv0815880311 #ygrps-yiv-1108055033yiv0815880311ygrp-sponsor #ygrps-yiv-1108055033yiv0815880311ygrp-lc #ygrps-yiv-1108055033yiv0815880311hd {
margin:10px 0px;font-weight:700;font-size:78%;line-height:122%;}
#ygrps-yiv-1108055033 #ygrps-yiv-1108055033yiv0815880311 #ygrps-yiv-1108055033yiv0815880311ygrp-sponsor #ygrps-yiv-1108055033yiv0815880311ygrp-lc .ygrps-yiv-1108055033yiv0815880311ad {
margin-bottom:10px;padding:0 0;}
#ygrps-yiv-1108055033 #ygrps-yiv-1108055033yiv0815880311 #ygrps-yiv-1108055033yiv0815880311actions {
font-family:Verdana;font-size:11px;padding:10px 0;}
#ygrps-yiv-1108055033 #ygrps-yiv-1108055033yiv0815880311 #ygrps-yiv-1108055033yiv0815880311activity {
background-color:#e0ecee;float:left;font-family:Verdana;font-size:10px;padding:10px;}
#ygrps-yiv-1108055033 #ygrps-yiv-1108055033yiv0815880311 #ygrps-yiv-1108055033yiv0815880311activity span {
font-weight:700;}
#ygrps-yiv-1108055033 #ygrps-yiv-1108055033yiv0815880311 #ygrps-yiv-1108055033yiv0815880311activity span:first-child {
text-transform:uppercase;}
#ygrps-yiv-1108055033 #ygrps-yiv-1108055033yiv0815880311 #ygrps-yiv-1108055033yiv0815880311activity span a {
color:#5085b6;text-decoration:none;}
#ygrps-yiv-1108055033 #ygrps-yiv-1108055033yiv0815880311 #ygrps-yiv-1108055033yiv0815880311activity span span {
color:#ff7900;}
#ygrps-yiv-1108055033 #ygrps-yiv-1108055033yiv0815880311 #ygrps-yiv-1108055033yiv0815880311activity span .ygrps-yiv-1108055033yiv0815880311underline {
text-decoration:underline;}
#ygrps-yiv-1108055033 #ygrps-yiv-1108055033yiv0815880311 .ygrps-yiv-1108055033yiv0815880311attach {
clear:both;display:table;font-family:Arial;font-size:12px;padding:10px 0;width:400px;}
#ygrps-yiv-1108055033 #ygrps-yiv-1108055033yiv0815880311 .ygrps-yiv-1108055033yiv0815880311attach div a {
#ygrps-yiv-1108055033 #ygrps-yiv-1108055033yiv0815880311 .ygrps-yiv-1108055033yiv0815880311attach img {
border:none;padding-right:5px;}
#ygrps-yiv-1108055033 #ygrps-yiv-1108055033yiv0815880311 .ygrps-yiv-1108055033yiv0815880311attach label {
display:block;margin-bottom:5px;}
#ygrps-yiv-1108055033 #ygrps-yiv-1108055033yiv0815880311 .ygrps-yiv-1108055033yiv0815880311attach label a {
#ygrps-yiv-1108055033 #ygrps-yiv-1108055033yiv0815880311 blockquote {
margin:0 0 0 4px;}
#ygrps-yiv-1108055033 #ygrps-yiv-1108055033yiv0815880311 .ygrps-yiv-1108055033yiv0815880311bold {
font-family:Arial;font-size:13px;font-weight:700;}
#ygrps-yiv-1108055033 #ygrps-yiv-1108055033yiv0815880311 .ygrps-yiv-1108055033yiv0815880311bold a {
#ygrps-yiv-1108055033 #ygrps-yiv-1108055033yiv0815880311 dd.ygrps-yiv-1108055033yiv0815880311last p a {
font-family:Verdana;font-weight:700;}
#ygrps-yiv-1108055033 #ygrps-yiv-1108055033yiv0815880311 dd.ygrps-yiv-1108055033yiv0815880311last p span {
margin-right:10px;font-family:Verdana;font-weight:700;}
#ygrps-yiv-1108055033 #ygrps-yiv-1108055033yiv0815880311 dd.ygrps-yiv-1108055033yiv0815880311last p span.ygrps-yiv-1108055033yiv0815880311yshortcuts {
margin-right:0;}
#ygrps-yiv-1108055033 #ygrps-yiv-1108055033yiv0815880311 div.ygrps-yiv-1108055033yiv0815880311attach-table div div a {
#ygrps-yiv-1108055033 #ygrps-yiv-1108055033yiv0815880311 div.ygrps-yiv-1108055033yiv0815880311attach-table {
width:400px;}
#ygrps-yiv-1108055033 #ygrps-yiv-1108055033yiv0815880311 div.ygrps-yiv-1108055033yiv0815880311file-title a, #ygrps-yiv-1108055033 #ygrps-yiv-1108055033yiv0815880311 div.ygrps-yiv-1108055033yiv0815880311file-title a:active, #ygrps-yiv-1108055033 #ygrps-yiv-1108055033yiv0815880311 div.ygrps-yiv-1108055033yiv0815880311file-title a:hover, #ygrps-yiv-1108055033 #ygrps-yiv-1108055033yiv0815880311 div.ygrps-yiv-1108055033yiv0815880311file-title a:visited {
#ygrps-yiv-1108055033 #ygrps-yiv-1108055033yiv0815880311 div.ygrps-yiv-1108055033yiv0815880311photo-title a, #ygrps-yiv-1108055033 #ygrps-yiv-1108055033yiv0815880311 div.ygrps-yiv-1108055033yiv0815880311photo-title a:active, #ygrps-yiv-1108055033 #ygrps-yiv-1108055033yiv0815880311 div.ygrps-yiv-1108055033yiv0815880311photo-title a:hover, #ygrps-yiv-1108055033 #ygrps-yiv-1108055033yiv0815880311 div.ygrps-yiv-1108055033yiv0815880311photo-title a:visited {
#ygrps-yiv-1108055033 #ygrps-yiv-1108055033yiv0815880311 div#ygrps-yiv-1108055033yiv0815880311ygrp-mlmsg #ygrps-yiv-1108055033yiv0815880311ygrp-msg p a span.ygrps-yiv-1108055033yiv0815880311yshortcuts {
font-family:Verdana;font-size:10px;font-weight:normal;}
#ygrps-yiv-1108055033 #ygrps-yiv-1108055033yiv0815880311 .ygrps-yiv-1108055033yiv0815880311green {
color:#628c2a;}
#ygrps-yiv-1108055033 #ygrps-yiv-1108055033yiv0815880311 .ygrps-yiv-1108055033yiv0815880311MsoNormal {
margin:0 0 0 0;}
#ygrps-yiv-1108055033 #ygrps-yiv-1108055033yiv0815880311 o {
font-size:0;}
#ygrps-yiv-1108055033 #ygrps-yiv-1108055033yiv0815880311 #ygrps-yiv-1108055033yiv0815880311photos div {
float:left;width:72px;}
#ygrps-yiv-1108055033 #ygrps-yiv-1108055033yiv0815880311 #ygrps-yiv-1108055033yiv0815880311photos div div {
border:1px solid #666666;height:62px;overflow:hidden;width:62px;}
#ygrps-yiv-1108055033 #ygrps-yiv-1108055033yiv0815880311 #ygrps-yiv-1108055033yiv0815880311photos div label {
color:#666666;font-size:10px;overflow:hidden;text-align:center;white-space:nowrap;width:64px;}
#ygrps-yiv-1108055033 #ygrps-yiv-1108055033yiv0815880311 #ygrps-yiv-1108055033yiv0815880311reco-category {
font-size:77%;}
#ygrps-yiv-1108055033 #ygrps-yiv-1108055033yiv0815880311 #ygrps-yiv-1108055033yiv0815880311reco-desc {
font-size:77%;}
#ygrps-yiv-1108055033 #ygrps-yiv-1108055033yiv0815880311 .ygrps-yiv-1108055033yiv0815880311replbq {
margin:4px;}
#ygrps-yiv-1108055033 #ygrps-yiv-1108055033yiv0815880311 #ygrps-yiv-1108055033yiv0815880311ygrp-actbar div a:first-child {
margin-right:2px;padding-right:5px;}
#ygrps-yiv-1108055033 #ygrps-yiv-1108055033yiv0815880311 #ygrps-yiv-1108055033yiv0815880311ygrp-mlmsg {
font-size:13px;font-family:Arial, helvetica, clean, sans-serif;}
#ygrps-yiv-1108055033 #ygrps-yiv-1108055033yiv0815880311 #ygrps-yiv-1108055033yiv0815880311ygrp-mlmsg table {
font-size:inherit;font:100%;}
#ygrps-yiv-1108055033 #ygrps-yiv-1108055033yiv0815880311 #ygrps-yiv-1108055033yiv0815880311ygrp-mlmsg select, #ygrps-yiv-1108055033 #ygrps-yiv-1108055033yiv0815880311 input, #ygrps-yiv-1108055033 #ygrps-yiv-1108055033yiv0815880311 textarea {
font:99% Arial, Helvetica, clean, sans-serif;}
#ygrps-yiv-1108055033 #ygrps-yiv-1108055033yiv0815880311 #ygrps-yiv-1108055033yiv0815880311ygrp-mlmsg pre, #ygrps-yiv-1108055033 #ygrps-yiv-1108055033yiv0815880311 code {
font:115% monospace;}
#ygrps-yiv-1108055033 #ygrps-yiv-1108055033yiv0815880311 #ygrps-yiv-1108055033yiv0815880311ygrp-mlmsg * {
line-height:1.22em;}
#ygrps-yiv-1108055033 #ygrps-yiv-1108055033yiv0815880311 #ygrps-yiv-1108055033yiv0815880311ygrp-mlmsg #ygrps-yiv-1108055033yiv0815880311logo {
padding-bottom:10px;}
#ygrps-yiv-1108055033 #ygrps-yiv-1108055033yiv0815880311 #ygrps-yiv-1108055033yiv0815880311ygrp-msg p a {
font-family:Verdana;}
#ygrps-yiv-1108055033 #ygrps-yiv-1108055033yiv0815880311 #ygrps-yiv-1108055033yiv0815880311ygrp-msg p#ygrps-yiv-1108055033yiv0815880311attach-count span {
color:#1E66AE;font-weight:700;}
#ygrps-yiv-1108055033 #ygrps-yiv-1108055033yiv0815880311 #ygrps-yiv-1108055033yiv0815880311ygrp-reco #ygrps-yiv-1108055033yiv0815880311reco-head {
color:#ff7900;font-weight:700;}
#ygrps-yiv-1108055033 #ygrps-yiv-1108055033yiv0815880311 #ygrps-yiv-1108055033yiv0815880311ygrp-reco {
margin-bottom:20px;padding:0px;}
#ygrps-yiv-1108055033 #ygrps-yiv-1108055033yiv0815880311 #ygrps-yiv-1108055033yiv0815880311ygrp-sponsor #ygrps-yiv-1108055033yiv0815880311ov li a {
font-size:130%;text-decoration:none;}
#ygrps-yiv-1108055033 #ygrps-yiv-1108055033yiv0815880311 #ygrps-yiv-1108055033yiv0815880311ygrp-sponsor #ygrps-yiv-1108055033yiv0815880311ov li {
font-size:77%;list-style-type:square;padding:6px 0;}
#ygrps-yiv-1108055033 #ygrps-yiv-1108055033yiv0815880311 #ygrps-yiv-1108055033yiv0815880311ygrp-sponsor #ygrps-yiv-1108055033yiv0815880311ov ul {
margin:0;padding:0 0 0 8px;}
#ygrps-yiv-1108055033 #ygrps-yiv-1108055033yiv0815880311 #ygrps-yiv-1108055033yiv0815880311ygrp-text {
font-family:Georgia;}
#ygrps-yiv-1108055033 #ygrps-yiv-1108055033yiv0815880311 #ygrps-yiv-1108055033yiv0815880311ygrp-text p {
margin:0 0 1em 0;}
#ygrps-yiv-1108055033 #ygrps-yiv-1108055033yiv0815880311 #ygrps-yiv-1108055033yiv0815880311ygrp-text tt {
font-size:120%;}
#ygrps-yiv-1108055033 #ygrps-yiv-1108055033yiv0815880311 #ygrps-yiv-1108055033yiv0815880311ygrp-vital ul li:last-child {
border-right:none !important;}
