Once you make a change, the fields you decided to keep track of change gets written in a log table. Going under Part Maintenance, you can access the changeLog journal via the menu Actions.
When you create a change log, it will track the date, name, and time the change was applied:, so you do not need to specifically select WHO made the change from the table select fields (it happens automatically).
