Change Log vs Audit Log
Hi Jeni,
Go to Executive Analysis->Business Activity Manager->Edit->Add. Go to
drop down on "Table" and click on the Table you want to create a log.
Click "Select" and add or remove the fields you want to track. Make
sure the "Create log" box is checked. We track everything here (all
fields and all tables). Just be aware of the existing size of your
database and monitor its growth - because it will.
Hope this helps.
Tanya Jernigan, V.P.
tjernigan@... <mailto:tjernigan@...>
www.waterjetparts.com <http://www.waterjetparts.com/>
H2O Jet, Inc.
1043-D Kaiser Rd. SW
Olympia, WA 98512
360-866-7161 Phone
360-866-7610 Fax
_____
Sent: Thursday, March 16, 2006 7:17 AM
Subject: [Vantage] Change Log vs Audit Log
We are on 6.10.519 and can create an audit log in job management and
quoting only. Epicor told me that even in 8.0 these are the only two
locations for this feature.
So then how do you make the change log work? There isn't a box to check
in company configuration but Help says it's out there we just can't
figure out how to turn it on.
Any help would be appreciated.
Jeni Wilson
Boyer Machine
_____
Jeni Wilson
Boyer Machine
