I am doing a web portal that is using EPICOR REST services, one of the task for this Web portal is to be able to change the password of my Epicor Account, so then, I am trying to use the following services Custom methods, Ice.BO.User.FileSvc / ChangePassword, this method request 3 parameters
userId
currentPassword
newPassword
currentPassword and newPassword require to be encrypted, my question is…
Do you know what kind of encryption Epicor require?
I tried to use some examples from the following link
but I am not able to make it work, in the other hand the link above suggest to use the following dll, Epicor.System.dll by using the following code
// Returns: 46uIY6/nQjHL5mX1KeE/7NtEXD3MIOblGxpVRH5ZWXNORGsNwT3WHg== for example. Epicor.Security.Cryptography.SHA.Hasher.ComputeHash(“manager”);
Using the same dll, the code above is not available in 10.2.300, this is the code available
using System;
using System.Collections.Generic;
using System.Linq;
using System.Text;
using System.Threading.Tasks;
using System.Security.Cryptography;
@erzt23 did you get this working? I also have a need for this and trying to call UserFileSvc.ChangePassword but it is not accepting the byte array I am computing for the current and new password.
This is the error I am getting
See more info in the Inner Exception section of Exception Details. ---> System.Security.Cryptography.CryptographicException: Error occurred while decoding OAEP padding.
