Change Epicor Column Label
Is it possible to change the column label for a column in an Epicor Table? We would like to change the CommentText label in the JobHead table from Resolution Comment to Job Comments.
You can go into Extended Property Maintenance for that field and set a Label:
That will give you this:
That worked, thanks for the quick help!
