Hello,
I am customizing the AR invoice entry screen so that users can click a button that will open up a customer payment portal. With help from Jose I was able to get the button working but I would like to make it read only on load and when a record is selected the field “CustPortal_c” is checked, if empty the button should be read only if not its enabled.
I’ve read a few forums and can’t use a row rule because AR entry doesn’t a text field to not be read only. Here’s my stab at this
// Custom code for ARInvoiceForm
// Created: 2/12/2021 1:11:07 PM
extern alias Erp_Contracts_BO_ARInvoice;
extern alias Erp_Contracts_BO_ARPromissoryNotes;
extern alias Erp_Contracts_BO_ARInvSearch;
extern alias Erp_Contracts_BO_ARInvcDtlSearch;
extern alias Erp_Contracts_BO_Company;
extern alias Erp_Contracts_BO_Customer;
extern alias Erp_Contracts_BO_Part;
extern alias Erp_Adapters_Customer;
using System;
using System.ComponentModel;
using System.Data;
using System.Diagnostics;
using System.Windows.Forms;
using Erp.Adapters;
using Erp.UI;
using Ice.Lib;
using Ice.Adapters;
using Ice.Lib.Customization;
using Ice.Lib.ExtendedProps;
using Ice.Lib.Framework;
using Ice.Lib.Searches;
using Ice.UI.FormFunctions;
public class Script
private EpiDataView edvCustomer;
private EpiDataView edvInvcHead;
this.edvCustomer = ((EpiDataView)(this.oTrans.EpiDataViews["Customer"]));
this.edvInvcHead = ((EpiDataView)(this.oTrans.EpiDataViews["InvcHead"]));
this.edvInvcHead.EpiViewNotification += new EpiViewNotification(this.edvInvcHead_EpiViewNotification);
this.btnCustPortal.Click += new System.EventHandler(this.btnCustPortal_Click);
this.btnCustPortal.Click -= new System.EventHandler(this.btnCustPortal_Click);
this.edvInvcHead.EpiViewNotification -= new EpiViewNotification(this.edvInvcHead_EpiViewNotification);
this.edvInvcHead = null;
// Begin Custom Code Disposal
// End Custom Code Disposal
private void ARInvoiceForm_Load(object sender, EventArgs args)
// Add Event Handler Code
btnCustPortal.ReadOnly = true;
private void edvInvcHead_EpiViewNotification(EpiDataView view, EpiNotifyArgs args)
// view.dataView[args.Row]["FieldName"]
// args.Row, args.Column, args.Sender, args.NotifyType
// NotifyType.Initialize, NotifyType.AddRow, NotifyType.DeleteRow, NotifyType.InitLastView, NotifyType.InitAndResetTreeNodes
if ((args.NotifyType == EpiTransaction.NotifyType.AddRow))
if ((args.Row > -1))
EpiDataView edvCustomer = ((EpiDataView)(this.oTrans.EpiDataViews["Customer"]));
System.Data.DataRow edvCustomerRow = edvCustomer.CurrentDataRow;
string cport = edvCustomerRow["CustPortal_c"].ToString();
if ((!String.IsNullOrEmpty(cport)))
else
btnCustPortal.ReadOnly = false;
private void btnCustPortal_Click(object sender, System.EventArgs args)
var myDv = oTrans.Factory("Customer");//Assuming Customer is the name of your Customer DataView
string url=(string) myDv.dataView[myDv.Row]["CustPortal_c"];
Process.Start(url);
Row Rules will always be the best option. I would recommend that the field get mapped to something (like the web address of the customer portal?) so the row rule can apply logic to the field. However, you can use custom code as the action instead to disable the button control.
I added a text box mapped to this field so I could monitor it’s value while testing.
Now with your suggestion i’ve added this, but I’m not sure how to disable the button in this
private void CreateRowRuleCustomerCustPortal_cEquals_x()
// Description: btnDisable
// **** begin autogenerated code ****
ControlSettings controlSettings1EpiReadOnly = new ControlSettings();
controlSettings1EpiReadOnly.SetStyleSetName("EpiReadOnly");
RuleAction epireadonlyCustomer_CustPortal_c = RuleAction.AddControlSettings(this.oTrans, "Customer.CustPortal_c", controlSettings1EpiReadOnly);
RuleAction[] ruleActions = new RuleAction[] {
epireadonlyCustomer_CustPortal_c};
// Create RowRule and add to the EpiDataView.
RowRule rrCreateRowRuleCustomerCustPortal_cEquals_x = new RowRule("Customer.CustPortal_c", RuleCondition.Equals, "", ruleActions);
((EpiDataView)(this.oTrans.EpiDataViews["Customer"])).AddRowRule(rrCreateRowRuleCustomerCustPortal_cEquals_x);
// **** end autogenerated code ****
Likely this is not a good example if there isn’t already a field associated with the Customer Portal.
For this, you will need custom code in the Row Rule Action.
Ahh!! I got it!
After reading that the binding doesn’t have to be real I changed it and now its good.
// Created: 2/16/2021 10:11:37 AM
using System;
using System.Data;
using Erp.Adapters;
using Erp.UI;
using Ice.Lib;
using Ice.Adapters;
public class Script
this.epiButtonC1.Click += new System.EventHandler(this.epiButtonC1_Click);
CreateRowRuleCustomerCustPortal_cEquals_x();;
this.epiButtonC1.Click -= new System.EventHandler(this.epiButtonC1_Click);
private void epiButtonC1_Click(object sender, System.EventArgs args)
Process.Start(url);
RuleAction disabledCustomer_btnCustPortal = RuleAction.AddControlSettings(this.oTrans, "Customer.btnCustPortal", SettingStyle.Disabled);
disabledCustomer_btnCustPortal};
