Tony,
Most default values are either in Company or Plant Configuration Maintenance or they are part of the base code, usually with some type of logic applied.
For instance, by default a NEW customer record should be of Type 'Suspect'
From there if a Quote is put on for this customer, the customer type will change to 'Prospect'
Or if a Sales Order is entered for this customer, the customer type will change to 'Customer'
If your installation is not working this way, then you may have a bug.
Outside of these options, your next easiest way to override a default is with a BPM.
-Rick Bird
IT Software Administrator
Rowmark, LLC.
-Rick Bird
Rowmark, LLC.
--- In vantage@yahoogroups.com, Tony Hughes <thughes281@...> wrote:
> In 8.03.409a, how do you change the default value of a new record?
> Example, for a new Customer record, default value for CustomerType is CUS. If I want to change a new Customer record to default at SUS or PRO, for example, what is simplest way to do that?
> I'm assuming there are easier ways than writing a BPM, or is BPM the only way?
> Thanks for any help.
