Certs (was: Progress/dbf)
Thanks Lonnie, but we won't be buying Provision anytime soon. Empty pockets.
Your situation is much more complicated than mine. Our Certs consist of
Basic information about the part (All exist on the Packing Slip) along with
some additional verbiage. All I really need is a subreport in Crystal. I
haven't done this yet, but it seems pretty straight forward. The big problem
is finding some way to trigger this subreport (while printing the Packing
Slip), that is based off of a field in the Customer Master. We've given our
shipper all kinds of red flags, as to when a cert is needed, but she still
manages to miss some. The best solution is to have it print automatically
with the Packing Slip. Does anybody know if it is possible to set a VB form
in the Customer Master, and pull the information into another VB Form in
either the ShipHead or ShipDtl tables? If I could do this, I would be all
set. I guess I should not have slept through that VB class.... Les
> -----Original Message-----
> From: lonniedrew [SMTP:lonniedrew@...]
> Sent: Thursday, January 17, 2002 6:57 PM
> To: vantage@yahoogroups.com
> Subject: [Vantage] Re: Certs (was: Progress/dbf)
> Les, since this is fresh on my mind I decided to elaborate on our
> solution.
> Steve, thanks for the offer. Please forward as soon as possible.
> I hope a further discussion will be beneficial to both of yours.
> As for my program, I'm proud of it as a Progress-only, push button
> solution, with a "verbose" and detailed print out. I can't believe
> Crystal could have worked any better.
> I'm sorry I can't upload the source code. All the techniques used in
> this program exist in the source code section of Yahoo Files, at
> least in examples I've previously uploaded.
> I was able to upload screen shots of the program, without using MORE
> Yahoo space, by deleting a few of the items in a zipped file I
> earlier uploaded under misc called "SnapShots.zip - Program snapshots
> illustrating what can be done in Provision development environment".
> If anyone would like to download and follow along they are....
> Certify.bmp - Main cert and analysis entry screen
> ViewCert.bmp - View only cert browze screen for reference. Can be
> sorted by certnum, entry date, customer or mold number.
> Cert.bmp - Sample cert.
> There's also a Coded Stamp selection dialog which is a data entry
> time saver, user can copy previously entered data and analyses.
> A PROGRESS-ONLY SOLUTION
> I've found that ProVision and Report Builder working together can
> produce fine results. I would probably have never attempted this
> without AppBuilder. There are over 70 widgets on the interface.
> Dragging and dropping these at will, and having the code
> automatically generated, probably cut development time by days. Data
> is stored in a separate Progress database, running alongside
> Vantage. There are over 80 calculated fields in the cert
> report/form, and over 60 aggregates.
> PROGRAM FLOW FROM USER PERSPECTIVE
> The user enters the order number, and a trigger displays and records
> the customer PO and shipping information. With the order line
> entered, our part number and the customer part number is displayed.
> If analyses of the current heat were entered for a previous cert, the
> user can double-click on the Coded Stamp field, select one, and is
> given an option to copy the analyses to the current cert. Comments
> can be recorded and printed on cert.
> The program will allow as many analyses as needed, but currently only
> the first 3 will print. If necessary, per customer request,
> unlimited number can be added.
> Batch printing is also supported. As each cert is created, it is
> marked to print. Pushing "Print" gives user choice of current cert
> or all entered that have not yet printed. Once printed it is marked
> NOT to print again, but can be reset is user enters the cert,
> retrieves data, and presses "Save".
> FUTURE ENHANCEMENTS
> There's still too much paper and manual labor for my taste. I hope
> to have pour department enter the actual analyses in a separate GUI.
> I also hope to store ASTM and customer specs in an addressable format
> for automatic comparison and alerts. There are already interfaces
> nearly completed for these.
> IN CONCLUSION
> If you don't have ProVision, I hope this project and the example I've
> discussed will convince you to purchase the license. I'll continue
> to post code and will be glad to share any advice to help the
> learning curve. We ourselves are our best source for programming
> info.
> Lonnie Drew
> Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must
> have already linked your email address to a yahoo id to enable access. )
> (1) To access the Files Section of our Yahoo!Group for Report Builder and
> Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
This 4GL coding newbie was hoping that changing my exports to dbf
from csv would be as simple as changing the file extensions. Sure.
I've found some information in the Files section on Progress and dbf,
but I'm relatively sure that I'm not ready for that. Second "stretch"
of the day. Is there a way to setup a .P file that will run an export
that was created using the export utility? These dbf files are to be
linked to MS Access. I don't want to use ODBC, and I don't want the
end user to have access to the export utility. Any words of wisdom?
Les Tingley
MIS
Decorated Products
I posted the dbf code, and have since abandoned that approach. I now use
ADO and export to an Access Database directly, whenever CSV isn't good
enough.
http://groups.yahoo.com/group/vantage/files/Progress%20Code/ADOPartExample.p
in order to utilize ADO, you need the latest MDAC drivers off the microsoft
site.
http://www.microsoft.com/data/download.htm
Please let me know if you have any questions...
Thaddeus
Sent: Wednesday, January 16, 2002 9:30 AM
Subject: [Vantage] Progress/dbf
Les Tingley
MIS
Decorated Products
Its when I hear topics like this that I remember why we went to SQL Server.
Sympathies, :)
Jeremy Leonard
IT Manager
K-T Corporation
Vantage 5.10.114 SQL Server
Sent: Wednesday, January 16, 2002 1:15 PM
To: 'vantage@yahoogroups.com'
Subject: RE: [Vantage] Progress/dbf
enough.
site.
Thaddeus
Les Tingley
MIS
Decorated Products
One thing I forgot to mention in the code: The program does not create a
database, it can only add records to an existing database.
Solution: Create the database file, with the appropriate table, and fields,
but no records, and copy a blank it the c:\vntgwrk directory.
Example:
/*the next two lines are progress code*/
dos silent "del c:\vntgwork\parts.mdb".
dos silent "copy X:\Path\Parts.MDB c:\vntgwrk\parts.mdb".
/*end code*/
the open statement for the recordset needs to be modified to reflect the
c:\vntgowrk path. whenever the program is run, the old file will be
deleted(assuming it is not still in use) and the blank database will be
copied from x:\path\ to the vntgwrk directory.
Thaddeus
Sent: Wednesday, January 16, 2002 10:15 AM
enough.
site.
Thaddeus
Les Tingley
MIS
Decorated Products
THANKS!! That was a really helpful comment!
Sent: Wednesday, January 16, 2002 12:25 PM
Server.
Sympathies, :)
Jeremy Leonard
IT Manager
K-T Corporation
enough.
microsoft
site.
Thaddeus
Les Tingley
MIS
Decorated Products
have
have
Yahoo! Groups Sponsor
ADVERTISEMENT
Well, if SQL server 25 user license was as cheap as the FREE mdac drivers,
which do not require the client to have Access, and would run on our single
PII-450 server, I'd be all over it. Six months of my beginners programming
time doesn't cost as much as what it would take to upgrade to SQL server.
However, once if the next version of vantage and progress end up being much
more stable in the SQL department, we may choose to migrate, as it could
reduce the amount of programming time required to implement various
solutions, and increase overall productivity in the long run.
Thaddeus
Sent: Wednesday, January 16, 2002 10:25 AM
Sympathies, :)
Jeremy Leonard
IT Manager
K-T Corporation
enough.
site.
Thaddeus
Les Tingley
MIS
Decorated Products
Sorry, I was just being smart. There was month after month of torment,
pain, and a few near fatalities from the Vantage SQL migration. Its just
nice to see something good come from it.
And btw, Microsoft Offers per processor licensing now for SQL 2000. No need
for CALS. Saves big on the upgrade.
Jeremy Leonard
IT Manager
K-T Corporation
Thanks Jeremy, no offense taken whatsoever.
I consider you to be a hero for taking the leap to SQL, and not turning back
despite the obstacles. Kind of like Cristopher Columbus ;-)
Thaddeus
Sent: Wednesday, January 16, 2002 10:52 AM
Jeremy Leonard
IT Manager
K-T Corporation
I'm not sure what you are hoping to do, but I link .csv files in Access all the time, and then run Crystal Reports off the .csv. We also have an extensive Excel-based program that runs off our .csv files automatically. Let me know if you want to see how to do it. We just update the .csv files nighty using the progress export like you are and Crystal is ready to be run off the Access database that is Linked to the .csv files.
These reports run much faster than through ODBC/Progress, which is why we're doing it. Speed. (Translated seconds compared to hours).
Troy Funte
Liberty Electronics
----- Original Message -----
Sent: Wednesday, January 16, 2002 12:29 PM
Les Tingley
MIS
Decorated Products
ADVERTISEMENT
I'm all ears!
Sent: Wednesday, January 16, 2002 12:48 PM
Subject: Re: [Vantage] Progress/dbf
Troy Funte
Liberty Electronics
Les Tingley
MIS
Decorated Products
ADVERTISEMENT
Now that's an interesting visual image
Sent: Wednesday, January 16, 2002 3:05 PM
I'm all ears!
OK. then....I'm all eyes. I couldn't very well *see* how to do it if I was
all ears, could I?
Sent: Wednesday, January 16, 2002 1:07 PM
I'm all ears!
Thanks Troy! This approach is going to save me ALOT of time.
Thaddeus
Troy Funte
Liberty Electronics
Les Tingley
MIS
Decorated Products
ADVERTISEMENT
I'm working on a write-up on it. I'll get it out in a few...
Troy Funte
Liberty Electronics
Sent: Wednesday, January 16, 2002 4:50 PM
Thaddeus
Troy Funte
Liberty Electronics
Les Tingley
MIS
Decorated Products
ADVERTISEMENT
ADVERTISEMENT
See new Thread called "Linking Access to a .CSV file (exported from Vantage) (WAS: Progress/dbf)" for details on this.
Troy Funte
Liberty Electronics
Thaddeus
Troy Funte
Liberty Electronics
Les Tingley
MIS
Decorated Products
ADVERTISEMENT
ADVERTISEMENT
Thanks Troy. I have done that as well, using some of the knowledge that you
had passed on to me previously. It was more a desire to learn to create an
export that could be saved directly to the Access DB. That as you know,
turned out to be a stretch for a Progress Coding Newbie. For the project
that I'm working on now, the export to csv, will work just fine.
For my next project, I'm going to need to automatically print "Certificates
of Compliance" based on Customer/parts that require them. I want this to be
maintainable by our customer service people. So I don't want to have to code
this all into Crystal. It would be better if a subreport fired off of a
field that lived in the Customer file. I couldn't make this work in 3.0, but
I'm hoping to find a way in 5.1. I haven't taken the time to look yet, but
if anybody has done this, or has some other way that they generated "Certs"
I'd love to hear it.
Les Tingley
MIS
Decorated Products
> From: Troy Funte [SMTP:tfunte@...]
> Sent: Wednesday, January 16, 2002 3:48 PM
> Troy Funte
> Liberty Electronics
> From: lptingley
> Thanks,
> Les Tingley
> MIS
> Decorated Products
> ADVERTISEMENT
Les,
We handle part certs with another Progress Db and an interface
written with ProVision AppBuilder which stores the data and prints a
certificate in RB.
They used to be typed on preprinted forms. I scanned one, placed it
on an RB report along with customer info, part info and chemical
analyses. It's only been deployed a couple of months, but is working
well.
Just another reason to persuade the powers-that-be to buy ProVision.
Lonnie
that you
create an
know,
project
print "Certificates
this to be
have to code
of a
3.0, but
yet, but
generated "Certs"
> Thanks,
> Les Tingley
> MIS
> Decorated Products
> > From: Troy Funte [SMTP:tfunte@e...]
> > To: vantage@y...
Access
have an
automatically.
the .csv
is ready
files.
is why
> > Troy Funte
> > Liberty Electronics
> > From: lptingley
> > To: vantage@y...
dbf
Sure.
and dbf,
Second "stretch"
export
to be
the
wisdom?
> > Thanks,
> > Les Tingley
> > MIS
> > Decorated Products
> > ADVERTISEMENT
You must
access. )
Builder
Service.
must
access. )
Builder and
Why don't you use a VB Form field to designate which cert is required and
use that field to show which report should be printed.
Cameron A. Janish
Misha1 cameron@...
Toll Free: 866-464-7421
Office: 708-445-7509
Cell: 630-712-9520
Office Fax: 630-893-1307
Direct Fax: 443-638-0489
Sent: Thursday, January 17, 2002 06:38 AM
you
"Certificates
be
code
but
"Certs"
Les Tingley
MIS
Decorated Products
an
automatically.
> Troy Funte
> Liberty Electronics
> From: lptingley
> Thanks,
> Les Tingley
> MIS
> Decorated Products
> ADVERTISEMENT
and
Les,
I wrote a custom application with the AppBuilder that we have been using for
3 years with good results. As a foundry, our certs are fairly complex since
we are reporting the chemical analysis and mechanical properties for each
heat (lot) shipping on a given order. In the background it compares the
chemical analysis to upper/lower control limits for various ASTM specs. The
application also allows the user to add canned statements to the cert and
approved signature blocks.
Report Builder wouldn't work for the output we needed so I ended up
exporting table values from Progress and then launching a Visual Basic
program that created a temporary database, sucked up the values from the
export and then called Crystal to display the report. The whole thing took
me about six months of part-time programming to get it right but it was
worth the effort.
Best of luck to you and your project! It was a great learning experience
for me.
Steve Sanders
Delta Centrifugal Corp
Sent: Thursday, January 17, 2002 6:38 AM
you
"Certificates
be
code
but
"Certs"
Les Tingley
MIS
Decorated Products
an
automatically.
> Troy Funte
> Liberty Electronics
> From: lptingley
> Thanks,
> Les Tingley
> MIS
> Decorated Products
> ADVERTISEMENT
and
