Have you ever dealt w/ Cascading Security Groups on Menu’s not even sure if its possible…
We have 7 companies right… and lets say John Doe in 1 needs Setup & General Ops… but in a company above he only needs Setup… - so in 1 company it should be hidden in another visible etc… I only would know if i duplicated Menu Folders, Icons and created Unique Menu Structure for each Company and or a complex Security IDs creation targeting specific companies. Is there any trick to Cascading Security Groups
Hello Haso,
What we do here (and learned from others in the group), is to create the security groups with the company ID in them. So, 100-OrderEntry, 200-OrderEntry, etc. with 000-OrderEntry for access to all companies. We then add the 000* and entries to the menus and then finally add the users to the groups. You should be able to accomplish what you want that way.
We also created a Menu items for local customizations for each company. Probably could have used just one but it’s not that much work.
Mark W.
