Capturing Data from one table to another
I believe that’s where you would be adding new records..
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of b_ordway
Sent: Thursday, March 28, 2013 2:56 PM
Subject: [Vantage] Re: Capturing Data from one table to another
>> a licensing restriction with open edge
>> which did not allow you to write to the db
>> unless you owned a developer license.
FYI V8 users.
I recently ran into a related problem with a BPM on 8.03.409C...
Not allowing a certain type of db write.
I believe I read a tech tip stating it became available by request about version 8.03.407.
I contacted the Epicor CAM & they did send me a Progess license at no cost.
--- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>, Jose Gomez <jose@...> wrote:
> Update table buffer was a procedure created to get around a licencing
> restriction with open edge which did not allow you to write to the db
> unless you owned a developer licence.
> Since 9 this restriction had either been removed or they included that
> licence in core epicor.
> One is not necessarily better than the other it's two ways to accomplish
> the same task.
> Internally update table buffer basically does an assign
> On Mar 27, 2013 6:24 PM, "Tom J. Christie" <tchristie@...>
> wrote:
> > My ABL is basically all cut and paste. I have no clue how it works! We had
> > customizations developed by a major consulting company and they used it. I
> > duplicated it and it worked. Assign seemed to only work in some occasions,
> > but table buffer always worked.
> > I ask because finding someone that actually knows what they are doing in
> > ABL (rather than use copy-pasters!) is rare and it is always good to know
> > if there is a better way.
> > Tom Christie | Information Technology Manager | AGM Container Controls,
> > Inc. | tchristie@...<mailto:tchristie@...> | t: 520.881.2130
> > ext 2176
> > From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>] On Behalf
> > Of Joshua Giese
> > Sent: Wednesday, March 27, 2013 3:15 PM
> > To: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>
> > Subject: Re: [Vantage] Re: Capturing Data from one table to another
> > Recommendation from Epicor would work either way but since you don't have
> > to use table buffer why use it?
> > Joshua Giese
> > CTO
> > 920.437.6400 Ext. 337
> > Site ID: 27450-E905700B2-SQL64
> > ----- Original Message -----
> > From: "Tom J. Christie" <tchristie@...<mailto:
> > tchristie%40agmcontainer.com>>
> > To: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>
> > Sent: Wednesday, March 27, 2013 5:12:36 PM
> > Subject: RE: [Vantage] Re: Capturing Data from one table to another
> > Any particular reason why that would be so?
> > Inc. | tchristie@...<mailto:tchristie%40agmcontainer.com>
> > <mailto: tchristie@...<mailto:tchristie%40agmcontainer.com>
> > > | t: 520.881.2130 ext 2176
> > From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com> [mailto:
> > vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com> ] On Behalf Of
> > jgiese1988
> > Sent: Wednesday, March 27, 2013 11:42 AM
> > I wanted to make a quick note that "updatetablebuffer" should ONLY be used
> > for 8.03 customers; 9.04+ installs should use the "assign
> > jobhead.checkboxxx = true" instead. For what it's worth :)
> > --- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com> <mailto:
> > vantage%40yahoogroups.com>, "Tom J. Christie" <tchristie@> wrote:
> > > Try something like:
> > > For first jobhead where ttjoboper.jobnum = jobhead.jobnum and
> > ttjoboper.company = jobhead.company:
> > > RUN lib\UpdateTableBuffer.p(input BUFFER JobHead:HANDLE,
> > 'CheckboxXX',1).
> > > End.
> > > My ABL syntax may be wrong, but the basic idea is that you use a For
> > first loop to get hold of the appropriate Jobhead record, then you use the
> > updatetablebuffer to change that record.
> > > Easy peasy.
> > Inc. | tchristie@<mailto:tchristie@> | t: 520.881.2130 ext 2176
> > > From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com> <mailto:
> > vantage%40yahoogroups.com> [mailto: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:
> > vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com>] On Behalf
> > Of Joshua Giese
> > > Sent: Wednesday, March 27, 2013 7:42 AM
> > > To: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com> <mailto:
> > > Subject: Re: [Vantage] RE: Capturing Data from one table to another
> > > Yup that's exactly what you would have to do. You would have to use the
> > ttJobOper keys that match the JobHead table and update it from there. Don't
> > have anything handy, but I got my examples for that from the user group
> > when I had to do something similar.
> > > Joshua Giese
> > > CTO
> > > From: "Ken Williams" <kwilliams@<mailto:
> > kwilliams%40intermountainelectronics.com>>
> > > Sent: Wednesday, March 27, 2013 9:38:59 AM
> > > Subject: [Vantage] RE: Capturing Data from one table to another
> > > I didn’t think that’d be possible because the JobHead table is not a
> > part of that data set. Unless you can open the table via Advanced BPM code?
> > Any chance someone has a snippet I could borrow?
> > Of Joshua Giese
> > > Sent: Wednesday, March 27, 2013 8:37 AM
> > > Subject: Re: [Vantage] Capturing Data from one table to another
> > > Create a BPM on the JobOper update that sets JobHead.CheckboxXX =
> > JobOper.Complete ?
> > > Joshua Giese
> > > CTO
> > > From: "Ken Williams" < kwilliams@<mailto:
> > kwilliams%40intermountainelectronics.com> <mailto:
> > > Sent: Wednesday, March 27, 2013 9:32:32 AM
> > > Subject: [Vantage] Capturing Data from one table to another
> > > We've developed a mini project schedule for our jobs within Job Entry.
> > It lists our most common milestones before it hits the floor, as well as
> > our main operations on the floor.
> > > What I'd like to be able to do, is when someone marks an operation
> > complete in job entry, have the related JobHead.CheckBox checked. Since the
> > operation complete is done on a labor record, which in turn affects
> > JobOper, I'm not sure how to push a change back to the JobHead table.
> > > Any thoughts or suggestions?
> > > Ken
We've developed a mini project schedule for our jobs within Job Entry. It lists our most common milestones before it hits the floor, as well as our main operations on the floor.
What I'd like to be able to do, is when someone marks an operation complete in job entry, have the related JobHead.CheckBox checked. Since the operation complete is done on a labor record, which in turn affects JobOper, I'm not sure how to push a change back to the JobHead table.
Ken
Create a BPM on the JobOper update that sets JobHead.CheckboxXX = JobOper.Complete ?
Joshua Giese
CTO
Ken
I didn’t think that’d be possible because the JobHead table is not a part of that data set. Unless you can open the table via Advanced BPM code? Any chance someone has a snippet I could borrow?
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Joshua Giese
Joshua Giese
CTO
From: "Ken Williams" <kwilliams@...<mailto:kwilliams%40intermountainelectronics.com>>
Ken
Yup that's exactly what you would have to do. You would have to use the ttJobOper keys that match the JobHead table and update it from there. Don't have anything handy, but I got my examples for that from the user group when I had to do something similar.
Joshua Giese
CTO
From: vantage@yahoogroups.com [mailto: vantage@yahoogroups.com ] On Behalf Of Joshua Giese
Joshua Giese
CTO
From: "Ken Williams" < kwilliams@... <mailto:kwilliams%40intermountainelectronics.com>>
Ken
Try something like:
For first jobhead where ttjoboper.jobnum = jobhead.jobnum and ttjoboper.company = jobhead.company:
RUN lib\UpdateTableBuffer.p(input BUFFER JobHead:HANDLE, 'CheckboxXX',1).
End.
My ABL syntax may be wrong, but the basic idea is that you use a For first loop to get hold of the appropriate Jobhead record, then you use the updatetablebuffer to change that record.
Easy peasy.
Tom Christie | Information Technology Manager | AGM Container Controls, Inc. | tchristie@...<mailto:tchristie@...> | t: 520.881.2130 ext 2176
Joshua Giese
CTO
From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> [mailto: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> ] On Behalf Of Joshua Giese
Joshua Giese
CTO
From: "Ken Williams" < kwilliams@...<mailto:kwilliams%40intermountainelectronics.com> <mailto:kwilliams%40intermountainelectronics.com>>
To: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com>
Ken
I wanted to make a quick note that "updatetablebuffer" should ONLY be used for 8.03 customers; 9.04+ installs should use the "assign jobhead.checkboxxx = true" instead. For what it's worth :)
--- In vantage@yahoogroups.com, "Tom J. Christie" <tchristie@...> wrote:
> Try something like:
> End.
> Easy peasy.
> Joshua Giese
> CTO
> Joshua Giese
> CTO
> Ken
Fantastic, thanks everyone for the insight.
Ken
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of jgiese1988
Sent: Wednesday, March 27, 2013 12:42 PM
--- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>, "Tom J. Christie" <tchristie@...<mailto:tchristie@...>> wrote:
> Try something like:
> End.
> Easy peasy.
> Tom Christie | Information Technology Manager | AGM Container Controls, Inc. | tchristie@...<mailto:tchristie@<mailto:tchristie@...%3cmailto:tchristie@>...> | t: 520.881.2130 ext 2176
> From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>] On Behalf Of Joshua Giese
> Joshua Giese
> CTO
> From: "Ken Williams" <kwilliams@...<mailto:kwilliams%40intermountainelectronics.com<mailto:kwilliams@...%3cmailto:kwilliams%40intermountainelectronics.com>>>
> From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com> [mailto: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com> ] On Behalf Of Joshua Giese
> Joshua Giese
> CTO
> From: "Ken Williams" < kwilliams@...<mailto:kwilliams%40intermountainelectronics.com<mailto:kwilliams@...%3cmailto:kwilliams%40intermountainelectronics.com>> <mailto:kwilliams%40intermountainelectronics.com>>
> To: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com>
> Ken
--- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>, "Tom J. Christie" <tchristie@...> wrote:
> Try something like:
> End.
> Easy peasy.
> Joshua Giese
> CTO
> Joshua Giese
> CTO
> Ken
Recommendation from Epicor would work either way but since you don't have to use table buffer why use it?
Joshua Giese
CTO
Tom Christie | Information Technology Manager | AGM Container Controls, Inc. | tchristie@... <mailto: tchristie@... > | t: 520.881.2130 ext 2176
From: vantage@yahoogroups.com [mailto: vantage@yahoogroups.com ] On Behalf Of jgiese1988
--- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>, "Tom J. Christie" <tchristie@...> wrote:
> Try something like:
> End.
> Easy peasy.
> From: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> [mailto: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>] On Behalf Of Joshua Giese
> Joshua Giese
> CTO
> To: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>
> From: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com> [mailto: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com> ] On Behalf Of Joshua Giese
> Joshua Giese
> CTO
> To: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com>
> Ken
My ABL is basically all cut and paste. I have no clue how it works! We had customizations developed by a major consulting company and they used it. I duplicated it and it worked. Assign seemed to only work in some occasions, but table buffer always worked.
I ask because finding someone that actually knows what they are doing in ABL (rather than use copy-pasters!) is rare and it is always good to know if there is a better way.
Joshua Giese
CTO
From: "Tom J. Christie" <tchristie@...<mailto:tchristie%40agmcontainer.com>>
Tom Christie | Information Technology Manager | AGM Container Controls, Inc. | tchristie@...<mailto:tchristie%40agmcontainer.com> <mailto: tchristie@...<mailto:tchristie%40agmcontainer.com> > | t: 520.881.2130 ext 2176
From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> [mailto: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> ] On Behalf Of jgiese1988
--- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com>, "Tom J. Christie" <tchristie@...> wrote:
> Try something like:
> End.
> Easy peasy.
> From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com> [mailto: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com>] On Behalf Of Joshua Giese
> Joshua Giese
> CTO
> To: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>
> From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com> [mailto: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com> ] On Behalf Of Joshua Giese
> Joshua Giese
> CTO
> To: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com>
> Ken
the same task.
> ext 2176
> Of Joshua Giese
> Joshua Giese
> CTO
> jgiese1988
> > Try something like:
> 'CheckboxXX',1).
> > End.
> > Easy peasy.
> Of Joshua Giese
> > Joshua Giese
> > CTO
> > I didn���t think that���d be possible because the JobHead table is not a
> Of Joshua Giese
> JobOper.Complete ?
> > Joshua Giese
> > CTO
> > Ken
I was told (I can't remember by whom or under what circumstances) that the "updatetablebuffer" needed to be used when updating a non-TT table in a BPM. We're using 9.04.507Al, and in these situations when I've tried to "assign" nothing happened, but when I used the "updatetablebuffer" it worked as anticipated.
Ernie Lowell
Diba Industries
> the same task.
> > ext 2176
> > Of Joshua Giese
> > Joshua Giese
> > CTO
> > jgiese1988
> > > Try something like:
> > 'CheckboxXX',1).
> > > End.
> > > Easy peasy.
> > Of Joshua Giese
> > > Joshua Giese
> > > CTO
> > Of Joshua Giese
> > JobOper.Complete ?
> > > Joshua Giese
> > > CTO
> > > Ken
When making the assignment directly you may need to put an exclusive-lock on the record to make a change stick.
Jim Kinneman
Encompass Solutions, Inc.
> Ernie Lowell
> Diba Industries
> > the same task.
> > On Mar 27, 2013 6:24 PM, "Tom J. Christie" <tchristie@>
> > > ext 2176
> > > Of Joshua Giese
> > > Joshua Giese
> > > CTO
> > > From: "Tom J. Christie" <tchristie@<mailto:
> > > Inc. | tchristie@<mailto:tchristie%40agmcontainer.com>
> > > <mailto: tchristie@<mailto:tchristie%40agmcontainer.com>
> > > jgiese1988
> > > > Try something like:
> > > 'CheckboxXX',1).
> > > > End.
> > > > Easy peasy.
> > > Of Joshua Giese
> > > > Joshua Giese
> > > > CTO
> > > Of Joshua Giese
> > > JobOper.Complete ?
> > > > Joshua Giese
> > > > CTO
> > > > Ken
FYI V8 users.
> the same task.
> > ext 2176
> > Of Joshua Giese
> > Joshua Giese
> > CTO
> > jgiese1988
> > > Try something like:
> > 'CheckboxXX',1).
> > > End.
> > > Easy peasy.
> > Of Joshua Giese
> > > Joshua Giese
> > > CTO
> > Of Joshua Giese
> > JobOper.Complete ?
> > > Joshua Giese
> > > CTO
> > > Ken
