We were having the same issue. Following is the documentation I received from Epicor support:
PROBLEM RESOLUTION:
GL > setup > GL Transaction type
Search/Select COSandWIP tran type
New > new revision > copy from existing (whichever revision is your current active) The new revision will appear at the bottom of the tree view, and will be in Draft status Revisions > book > detail tab Change summariziation to "Summarize"
Save
Revisions > Revision Detail Tab > choose Active from the Status Dropdown When it finishes, Save
The capture will now post in summarized format, as it did in version 8.x and prior
Version:
9.x
We are in the process of testing this out in our test environment this afternoon with the hopes of a shorter processing time.
Hope this helps you!
Carol
