Can't report quantity with PCID on job with Co-Parts? 2022.2.8
Hey folks,
Question: Is it possible to use PCID at the Report Quantity level on a job with coparts? When trying to report quantity via MES, the PCID field goes gray when I add a copart to the job.
Here’s the field help associated with the PCID field:
PCID
Specifies the PCID associated with the report quantity. When you enter, scan or select a PCID, you extract the internal PCID from the full PCID string, validate the package control status and validate that the PCID is valid for this report quantity.
Note: You can only enter and search for PCIDs that have the following criteria:
The PCID must have a status of WIPFG.
The job number in the package control item must match the job number for the report quantity.
Note: This field is only enabled if the following information is true:
**Your company has an AMM license. **
**The Package Control Enabled check box is selected for the site in Site Configuration. **
**The operation against which the quantity is reported is selected as the last operation or the last operation in the method. **
**The report quantity is greater than zero. **
**The activity is a production activity (not indirect, setup or rework). **
**The operation is not set to Auto Receive. **
The job against which the quantity is reported contains no sub-assemblies.
We’re good on these requirements, but it appears that the copart addition turns off the ability.
Any helpful info out there?
Joe
Update from Epicare:
Unfortunately this is intended.
This two are not compatible.
Right now there is no code supporting this process.
