During our 10.2.200.12 testing, our sales team noticed they can’t delete lines on sales orders, and get an error of:
We didn’t make any changes that I know of, and simply updated our Live 10.0.700.4 database to the latest (10.2.200.12), so none of the security setting should of changed. Reluctantly, I submitted and EpicCare case, and the tech’s response is to run SO Entry in base mode, and if that didn’t work (it didn’t), it’s because of a customization, and then I need to contact my CAM (for consulting). Argh… Upgrading shouldn’t be a wild goose chase.
(Fortune teller says: I bet this group helps me figure it out, rather than Epicor, and E10Help.com should get our six figure Epicor maintenance fee instead…)
Any idea where I should dig next?
I don’t recall anything in BPM’s that could be driving this (not sure how to trace this, error message below does say BPM, but clues are in Greek to me…). The only data directive on the OrderDtl table is for the change log. I’m not sure what to look for in the Service Security Maintenance app (since it’s restricting access to menu items).
Application Error
Error Detail
Message: Security prevents you from deleting rows in this table.
Program: Epicor.ServiceModel.dll
Method: ShouldRethrowNonRetryableException
Client Stack Trace
at Ice.TablesetBound3.DeleteRow(IceDataContext dataContext, String tableName, LinqRow dbRow, TablesetProfilingCollector parentTraceCollector) in C:\_Releases\ICE\RL3.2.200.0\Source\Framework\Epicor.Ice\Services\TablesetBound.cs:line 1376 at Ice.TablesetBound
3.WriteTable(IceDataContext dataContext, Int32 tableIndex, IIceTable table, TablesetProfilingCollector parentTraceCollector) in C:_Releases\ICE\RL3.2.200.0\Source\Framework\Epicor.Ice\Services\TablesetBound.cs:line 1007
at Ice.TablesetBound3.InnerUpdate[TUpdater](IceDataContext dataContext, TFullTableset tableset) in C:\_Releases\ICE\RL3.2.200.0\Source\Framework\Epicor.Ice\Services\TablesetBound.cs:line 892 at Erp.Services.BO.SalesOrderSvc.Update(SalesOrderTableset& ds) in C:\_Releases\ERP\UD10.2.200.12\Source\Server\Services\BO\SalesOrder\SalesOrder.Designer.cs:line 3898 at Epicor.Customization.Bpm.MethodCustomizationBase2
3.RunDirectives(TParam parameters) in C:_Releases\ICE\ICE3.2.200.12\Source\Server\Internal\Lib\Epicor.Customization.BPM\MethodCustomizationBase2.cs:line 197
at Epicor.Customization.Bpm.CustomizationBase23.Execute(TParam parameters) in C:\_Releases\ICE\ICE3.2.200.12\Source\Server\Internal\Lib\Epicor.Customization.BPM\CustomizationBase2.cs:line 73 at Epicor.Customization.Bpm.BO8A3809B7B8F74E1481D044B07DCBF5DA.SalesOrderSvcCustomization.Update(SalesOrderTableset& ds) at Erp.Services.BO.SalesOrderSvcFacade.Update(SalesOrderTableset& ds) in C:\_Releases\ERP\UD10.2.200.12\Source\Server\Services\BO\SalesOrder\SalesOrderSvcFacade.cs:line 8601 at SyncInvokeUpdate(Object , Object[] , Object[] ) at System.ServiceModel.Dispatcher.SyncMethodInvoker.Invoke(Object instance, Object[] inputs, Object[]& outputs) at Epicor.Hosting.OperationBoundInvoker.InnerInvoke(Object instance, Func
2 func) in C:_Releases\ICE\ICE3.2.200.12\Source\Framework\Epicor.System\Hosting\OperationBoundInvoker.cs:line 59
at Epicor.Hosting.OperationBoundInvoker.Invoke(Object instance, Func`2 func) in C:_Releases\ICE\ICE3.2.200.12\Source\Framework\Epicor.System\Hosting\OperationBoundInvoker.cs:line 47
at Epicor.Hosting.Wcf.EpiOperationInvoker.Invoke(Object instance, Object[] inputs, Object[]& outputs) in C:_Releases\ICE\ICE3.2.200.12\Source\Framework\Epicor.System\Hosting\Wcf\EpiOperationInvoker.cs:line 23
at System.ServiceModel.Dispatcher.DispatchOperationRuntime.InvokeBegin(MessageRpc& rpc)
at System.ServiceModel.Dispatcher.ImmutableDispatchRuntime.ProcessMessage5(MessageRpc& rpc)
at System.ServiceModel.Dispatcher.ImmutableDispatchRuntime.ProcessMessage11(MessageRpc& rpc)
at System.ServiceModel.Dispatcher.MessageRpc.Process(Boolean isOperationContextSet)
at Epicor.ServiceModel.Channels.ImplBase`1.ShouldRethrowNonRetryableException(Exception ex, DataSet[] dataSets)
at Erp.Proxy.BO.SalesOrderImpl.Update(SalesOrderDataSet ds)
at Erp.Adapters.SalesOrderAdapter.OnDelete()
at Ice.Lib.Framework.EpiBaseAdapter.Delete(DataRow dr)
at Erp.UI.App.SalesOrderEntry.Transaction.Delete()
