This is a new one on me. It’s a 2024.1 test environment. First time I am trying this in that environment.
I’ll try this as a domain admin and see if it changes.
Full text of error
## System Information ##
AppServer Connection: https://[REDACTED]
Form Name: Report Style Maintenance
Customization Name:
Menu ID: SUMT7500
Software Version: 4.3.100.0
Server Side Exception
The SSL connection could not be established, see inner exception.
## Error Detail ##
Description: The SSL connection could not be established, see inner exception.
##!Correlation ID:##! 31ef0375-dcf5-492d-92c5-fabb1c152377
## Client Stack Trace ##
at Epicor.ServiceModel.Channels.ImplBase.CallWithCommunicationFailureRetry(String methodName, ProxyValuesIn valuesIn, ProxyValuesOut valuesOut, RestRpcValueSerializer serializer)
at Epicor.ServiceModel.Channels.ImplBase.CallWithMultistepBpmHandling(String methodName, ProxyValuesIn valuesIn, ProxyValuesOut valuesOut, Boolean useSparseCopy)
at Epicor.ServiceModel.Channels.ImplBase.Call(String methodName, ProxyValuesIn valuesIn, ProxyValuesOut valuesOut, Boolean useSparseCopy)
at Ice.Proxy.BO.ReportImpl.ImportCustomSsrsReports(DataSet reports, String printProgram)
at Ice.Lib.Report.SsrsTransfer.UploadReports(String clientDirectory, String reportLocations)
at Ice.Lib.Report.UploadSsrsDialog.UploadReports(Session session, String selectedPath, String printProgram)
at Ice.Lib.Report.SsrsDialogBase.TransferReports(Session session, Action`1 showReportsTransfered)
at Ice.Lib.Report.UploadSsrsDialog.UploadReports(Form parentForm, Session session)
at Erp.UI.App.ReportEntry.ReportForm.UploadSsrsReport()
at Erp.UI.App.ReportEntry.ReportForm.OnClickMiscTool(String ToolKey)
at Ice.Lib.Framework.EpiBaseForm.handleToolClickInternal(String tKey, ToolClickEventArgs ea)
at Ice.Lib.Framework.EpiBaseForm.handleToolClick(String tKey, ToolClickEventArgs ea)
