BINGO!!
This works. Thanks for your help.
--- In vantage@yahoogroups.com, "Techno Babbler" <TechnoBabbly@...> wrote:
> All of your paths in the System Agent should be UNC, you then need to stop
> and restart the Task and Process Appservers for the new settings to take
> place.
> You should be sharing the MFGSYSDATA folder directly and use that path in
> the system agent, you should be able to access it through
> \\servername\mfgsysdata
> That is your problem, not anything else. The clients can't access via a
> local path, it has to be UNC.
> -----Original Message-----
> From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of
> dowden_tim
> Sent: Friday, December 03, 2010 5:55 AM
> To: vantage@yahoogroups.com
> Subject: [Vantage] Re: Cannot print from Vantage clients
> Tried this. Still getting the error message.
> --- In vantage@yahoogroups.com, "Blake Clemens" <blake.clemens@> wrote:
> > Are all your shared Epicor folders shared properly? Are you able to
> > open the run command and enter
> > \\YourVantageServerName\Epicor\MfgSysData\Reports
> > <file:///\\YourVantageServerName\Epicor\MfgSysData\Reports> and view
> > the folder?
> > Thanks,
> > Blake Clemens
> > IT Systems Engineer
> > Delmarva Millwork Corporation
> > (800) 360-2364 x132
> > Behalf Of dowden_tim
> > Sent: Wednesday, December 01, 2010 1:48 PM
> > Hi
> > Thanks for the response.
> > The client file setting is already set up this way. I have also tried
> > using the UNC path or the IP address in the System Agent fields but it
> > hasn't sorted out the problem. It's a weird one this. I'm running out
> > of ideas.
> > Tim
> > --- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> ,
> > "bw2868bond" <bwalker@> wrote:
> > > Make sure in SystemAgent the Client File setting is \\<your
> > server>\Epicor\MfgSysData
> > > right now it looks like it is telling Crystal that the report data
> > > is
> > on each clients local hard drive......
> > "dowden_tim" <timmyturnup@> wrote:
> > > > Hello
> > > > We have installed Vantage 8.03.409C (Progress) on a new server
> > (Windows 2008).
> > > > Whenever anyone tries to print any Vantage reports on their client
> > machine they get an error like the following
> > > > Could not find file 'c:\epicor\MfgSysData\Reports\TDOWDEN\PURCHASE
> > ORDER16124.XML'.
> > > > or
> > > > Could not find a part of the path
> > 'c:\epicor\MfgSysData\Reports\TDOWDEN\PURCHASE ORDER16124.XML'.
> > > > If I print using Vantage on the server itself then it prints just
> > fine.
> > > > Things we have tried to fix the problem:
> > > > 1.- Ran conversion 130.
> > > > 2.- Recreated system agent, didnt work
> > > > 3.- Checked security settings for the epicor folder on the server
> > > > as
> > well as the mfgsysdata folder and set them up full control for everyone.
> > > > 4.- Rebooted server and restarted db and appservers several times.
> > > > 5.- Uninstalled and reinstalled Vantage and Openedge on the server.
> > > > 6.- Latest patches applied to Vantage and OpenEdge.
> > > > 7.- Latest service pack applied to Crystal Runtime.
> > > > 7.- Epicor Support webexed in and were just as baffled as we were
> > having checked over several things.
> > > > Does anyone have any ideas?
> > > > Thanks
> > > > Tim Dowden
> > > > Guralp Systems Ltd
> Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must have
> (1) To access the Files Section of our Yahoo!Group for Report Builder and
> http://groups.yahoo.com/group/vantage/linksYahoo! Groups Links
