On the Supplier Master screen I have added UD22 table as a child using the wizard and linked the UD22View to the EpiBinding on an EpiUltraGrid. I can Add New UD22 records and I can Edit UD22 records through the Supplier Master screen but I cannot Delete records. When I select an UD22 record and click on the red “X” to delete nothing happens, not even an error.
To add this customization I used the EpicorERMCustomization_UserGuide_102600.pdf and followed the pages 525-535 on the User-Defined (UD) Table Add/Edit/Delete Functionality Wizard. I have repeated this process serval times with the same effect.
I’m not sure if I’m not doing something correctly or if these instructions are not complete. I do not know enough about C# to understand what is missing from the added code.
We are on Epicor release 10.2.600
Attached is the code that was generated from the wizard UD22 Child Table.txt (14.0 KB)
I think the wizard generated code just deletes the UD Child record(s) when the Parent is deleted.
Did you make any progress on this? I have a similar project and am finding it trickier than I thought… The wizard code is a great starting point but definitely lacking some important features.
