Cannot close quote when Task Assign
Hi
simple question
If a Quote as Tasks assign, to close the Quote at any time (before going througth the last task)
Is it possible to go to Action > Quote > Close Quote (because I cannot. message that I have an Active task)
Or
You must absolutely go to the tab Tasks > Detail – Select Complete and Lose
check Epicare, and user guide, cannot find if this is As design or a bug that I cannot close the Quote from the Action menu
thank you for your time
philippe
Not 100% sure, but I believe that is As Designed.
You can also use Task List to complete the task.
Hi John
Just received a message from Epicor
To confirm, yes it’s as design, now we know !
From Epicor
In order to close a Quote all mandatory tasks must be completed.
Going to Actions > Quote > Close Quote without completing tasks, will not let you close the quote. You must first go to Tasks Tab > Details > Complete and then you can close the quote from the actions menu.
Thank you!
Best regards.
