Can you bind UD fields to IssueReturn table?
Hi,
I am trying to add 4 textboxes on issue miscellaneous material entry.
I would like to bind those 4 textboxes to IR, so then I can create a BAQ using the PartTran table.
I’ve created UD fields for PartTran table, but I do not see those there in the “EpiBinding”.
Johnny
Have you already synched the tables and regenerated the data model?
Yeap
Did you run IISRESET after the regen?
yes, but I still cannot see those UD fields for IssueReturn…
IssueReturn DataView is not a direct view onto the PartTran table, you are pretty much SOL on this one I think. You could bind it to CallContextFields and use BPMs to copy them over…
I see! thank you very much for your help
