Can you add the customer search inside of a Quick search? Or add columns to existing search results?
Hello,
Not a dealbreaker but something I thought about adding.
I need to replace the Order Entry search so I can add some custom columns to the search results.
When I do a new Quick Search for this, I can do the Order # Prompt and the Order Types value list.
I was wondering if there was a way to add a Customer Search to fill in a prompt like the original.
As an alternative, is there a way to add columns (one of them is a UD field) to the existing search instead?
Any help is appreciated. Thanks!
it is possible to customize the quicksearch form, but that takes some work… why not simply use the “right-click” into the field… if you put the Customer ID into the quicksearch, I believe you should be able to right-click into it to search and return the correct customer ID.
This does this by default, (10.2.700)
Here is an example.
