Can one un-install a solution file? or if one installation is not successfully, how can one clean all the installed stuff in Epicor? Thank for your help.
In Solution Workbench, there is Delete Installed Solutions under the Actions menu. I have never used it so I don’t know much more about it.
Thank you very much, Jeromy. I don’t have the “delete installed solutions” under Actions in Solution Workbench.
What version are you on? I’m on 10.2.300.21.
10.1.500
Then I’m guessing it’s in a later release. I don’t know at what version it was introduced.
