Our users want to have the GL account #s in the Material Transaction Detail report. Anyone has this experience and know how to do? I know the material transaction detail report mainly uses the two tables, PartTran and Company. How can we associate GL #s with the PartTran? Which table should be used? Thanks.
Thanks a lot, Mark.
You could run into trouble because the GL account to use isn’t actually used until the Capture WIP/COS is run. It is at that time when the GL account is actually selected.
So a potential pitfall would be determining if there was a change to the GLC (or the thing the GLC is tied to) between when the material transaction report was printed, and when the Capture WIP/COS process is run.
Your Mtl Tran report would indicate the anticipated GL account
Thanks for your info, Calvin.
