Hi,
I created a button to open “Job Receipt to Inventory”.
Customization is very simple: I created the button and added “click” event to the customization.
private void epiButtonC1_Click(object sender, System.EventArgs args)
ProcessCaller.LaunchForm(this.oTrans, "IMGO3001"); // IMGO3001 is a standard menu ID
The problem is that when I click this button, Epicor will show the error message first and then opens the “Job receipt to Inventory”.
Error message:
Business Layer Exception
Job Not Found for Job Type MFG
Error Detail
Description: Job Not Found for Job Type MFG
Program: Erp.Services.BO.ReceiptsFromMfg.dll
Method: GetNewReceiptsFromMfgJobAsm
Line Number: 2591
Column Number: 17
Table: PartTran
Field: JobHead
Server Trace Stack: at Erp.Services.BO.ReceiptsFromMfgSvc.GetNewReceiptsFromMfgJobAsm(String pcJobNum, Int32 piAssemblySeq, String pcTranType, String pcProcessID, ReceiptsFromMfgTableset& ds) in C:_Releases\ERP\UD10.1.600.19\Source\Server\Services\BO\ReceiptsFromMfg\ReceiptsFromMfg.cs:line 2591
I have checked all BPM -s and cannot find any method or data BPM for this object / method or table / field!
I have tested to run the other programs menu ID and then this customization works well. Programs opens correctly, no any error messages.
What I’m doing wrong or how I can avoid this error message?
