<div class="ygrps-yiv-565174160yiv4287617288" id="ygrps-yiv-565174160yiv4287617288ygrp-text" style="">
<div class="ygrps-yiv-565174160yiv4287617288" dir="ltr" style=""><div class="ygrps-yiv-565174160yiv4287617288" style="font-family:verdana, sans-serif;font-size:small;">Issue Material form expects valuein to be a string with the RowID since you are not passing that value it fails to parse it / pull it up correctly. If you want to get around it either pass the MtlRowID from MtlQueue as ValueIN(which you probably wo'nt have) or change all your parameters to come in as the ContextValue and parse it out maybe</div>
Jose C Gomez
T: 904.469.1524 mobile
On Thu, Jun 19, 2014 at 2:59 PM, jyprksh@... [vantage] <vantage@yahoogroups.com> wrote:
<div class="ygrps-yiv-565174160yiv4287617288" style=""> <div class="ygrps-yiv-565174160yiv4287617288" style=""><span class="ygrps-yiv-565174160yiv4287617288" style="">Hi Epicor'ist,</span></div><div class="ygrps-yiv-565174160yiv4287617288" style=""><span class="ygrps-yiv-565174160yiv4287617288" style=""><br clear="none" class="ygrps-yiv-565174160yiv4287617288" style=""></span></div><div class="ygrps-yiv-565174160yiv4287617288" style=""><span class="ygrps-yiv-565174160yiv4287617288" style="">I am trying to call IssueMaterial form from job entry passing jobnum and mtl ... below is the code. Problem is, when the "IssueMaterialEntry" form loads, it comes up with<span class="ygrps-yiv-565174160yiv4287617288" style="font-weight:bold;"> error</span> " <span class="ygrps-yiv-565174160yiv4287617288" style="font-weight:bold;">A valid MtlQueueRowId is required</span>". But, after that error messagebox, data are populated with launchform option parameters.</span></div>
Private Sub IssueMaterialForm_Load(ByVal sender As Object, ByVal args As EventArgs)' Add Event Handler CodeIf Not(IssueMaterialForm.LaunchFormOptions is Nothing) ThenIf Not(IssueMaterialForm.LaunchFormOptions.ContextValue Is Nothing) ThenDim gn As Boolean = oTrans.GetNew()gn = trueDim ParamView As EpiDataView = CType(oTrans.EpiDataViews("IM"), EpiDataView)ParamView.dataView(ParamView.Row).BeginEdit()ParamView.dataView(ParamView.Row)("ToJobNum") = IssueMaterialForm.LaunchFormOptions.ContextValueParamView.dataView(ParamView.Row)("ToAssemblySeq") = 0ParamView.dataView(ParamView.Row)("ToJobSeq") = IssueMaterialForm.LaunchFormOptions.LikeParamView.dataView(ParamView.Row)("TranQty") = IssueMaterialForm.LaunchFormOptions.valueinParamView.dataView(ParamView.Row).EndEdit()oTrans.NotifyAll()End IfEnd IfEnd SubPrivate Sub epi_btn_LoadIssueMtlEntry_c_Click(ByVal sender As Object, ByVal args As System.EventArgs)Dim edv_c_w As EpiDataView = CType(oTrans.EpiDataViews("JobHead"), EpiDataView)Dim c_jobnum As StringDim IMRQty, reqQty,IssueQty as DecimalDim lfo As LaunchFormOptions = New LaunchFormOptions()c_jobnum = edv_c_w.dataView(edv_c_w.Row)("JobNum")reqQty = Convert.ToDecimal(epi_txt_required_c.Text)IssueQty = Convert.ToDecimal(ep_txt_issued_c.Text)IMRQty = reqQty-IssueQtylfo.IsModal = Truelfo.ContextValue = c_jobnumlfo.Like = epiUltraCombo_Mtl.Valuelfo.SuppressFormSearch = Truelfo.ValueIn = IMRQtyProcessCaller.LaunchForm(oTrans,"IMCS", lfo)End Sub#Epicor 9.05 700B ..Any assistance, greatly appreciated! I am using following example as template
Launch Sales Order with Customer Details from a Dashboard [SOLVED] - Toolbox for IT GroupsHow do I launch a sales order with the customer details from a dashboard? I have managed to customize a the dashboard to include a button on the …
Preview by Yahoo
</div> <div class="ygrps-yiv-565174160yiv4287617288" style="color:#fff;min-height:0;"></div>
</div>
<div class="ygrps-yiv-565174160yiv4287617288" style="color:#fff;height:0;"></div></div>
#ygrps-yiv-565174160 #ygrps-yiv-565174160yiv4287617288 #ygrps-yiv-565174160yiv4287617288ygrp-mkp hr {
border:1px solid #d8d8d8;}
#ygrps-yiv-565174160 #ygrps-yiv-565174160yiv4287617288 #ygrps-yiv-565174160yiv4287617288ygrp-mkp #ygrps-yiv-565174160yiv4287617288hd {
color:#628c2a;font-size:85%;font-weight:700;line-height:122%;margin:10px 0;}
#ygrps-yiv-565174160 #ygrps-yiv-565174160yiv4287617288 #ygrps-yiv-565174160yiv4287617288ygrp-mkp #ygrps-yiv-565174160yiv4287617288ads {
margin-bottom:10px;}
#ygrps-yiv-565174160 #ygrps-yiv-565174160yiv4287617288 #ygrps-yiv-565174160yiv4287617288ygrp-mkp .ygrps-yiv-565174160yiv4287617288ad {
padding:0 0;}
#ygrps-yiv-565174160 #ygrps-yiv-565174160yiv4287617288 #ygrps-yiv-565174160yiv4287617288ygrp-mkp .ygrps-yiv-565174160yiv4287617288ad p {
margin:0;}
#ygrps-yiv-565174160 #ygrps-yiv-565174160yiv4287617288 #ygrps-yiv-565174160yiv4287617288ygrp-mkp .ygrps-yiv-565174160yiv4287617288ad a {
color:#0000ff;text-decoration:none;}
#ygrps-yiv-565174160 #ygrps-yiv-565174160yiv4287617288 #ygrps-yiv-565174160yiv4287617288ygrp-sponsor #ygrps-yiv-565174160yiv4287617288ygrp-lc {
font-family:Arial;}
#ygrps-yiv-565174160 #ygrps-yiv-565174160yiv4287617288 #ygrps-yiv-565174160yiv4287617288ygrp-sponsor #ygrps-yiv-565174160yiv4287617288ygrp-lc #ygrps-yiv-565174160yiv4287617288hd {
margin:10px 0px;font-weight:700;font-size:78%;line-height:122%;}
#ygrps-yiv-565174160 #ygrps-yiv-565174160yiv4287617288 #ygrps-yiv-565174160yiv4287617288ygrp-sponsor #ygrps-yiv-565174160yiv4287617288ygrp-lc .ygrps-yiv-565174160yiv4287617288ad {
margin-bottom:10px;padding:0 0;}
#ygrps-yiv-565174160 #ygrps-yiv-565174160yiv4287617288 #ygrps-yiv-565174160yiv4287617288actions {
font-family:Verdana;font-size:11px;padding:10px 0;}
#ygrps-yiv-565174160 #ygrps-yiv-565174160yiv4287617288 #ygrps-yiv-565174160yiv4287617288activity {
background-color:#e0ecee;float:left;font-family:Verdana;font-size:10px;padding:10px;}
#ygrps-yiv-565174160 #ygrps-yiv-565174160yiv4287617288 #ygrps-yiv-565174160yiv4287617288activity span {
font-weight:700;}
#ygrps-yiv-565174160 #ygrps-yiv-565174160yiv4287617288 #ygrps-yiv-565174160yiv4287617288activity span:first-child {
text-transform:uppercase;}
#ygrps-yiv-565174160 #ygrps-yiv-565174160yiv4287617288 #ygrps-yiv-565174160yiv4287617288activity span a {
color:#5085b6;text-decoration:none;}
#ygrps-yiv-565174160 #ygrps-yiv-565174160yiv4287617288 #ygrps-yiv-565174160yiv4287617288activity span span {
color:#ff7900;}
#ygrps-yiv-565174160 #ygrps-yiv-565174160yiv4287617288 #ygrps-yiv-565174160yiv4287617288activity span .ygrps-yiv-565174160yiv4287617288underline {
text-decoration:underline;}
#ygrps-yiv-565174160 #ygrps-yiv-565174160yiv4287617288 .ygrps-yiv-565174160yiv4287617288attach {
clear:both;display:table;font-family:Arial;font-size:12px;padding:10px 0;width:400px;}
#ygrps-yiv-565174160 #ygrps-yiv-565174160yiv4287617288 .ygrps-yiv-565174160yiv4287617288attach div a {
#ygrps-yiv-565174160 #ygrps-yiv-565174160yiv4287617288 .ygrps-yiv-565174160yiv4287617288attach img {
border:none;padding-right:5px;}
#ygrps-yiv-565174160 #ygrps-yiv-565174160yiv4287617288 .ygrps-yiv-565174160yiv4287617288attach label {
display:block;margin-bottom:5px;}
#ygrps-yiv-565174160 #ygrps-yiv-565174160yiv4287617288 .ygrps-yiv-565174160yiv4287617288attach label a {
#ygrps-yiv-565174160 #ygrps-yiv-565174160yiv4287617288 blockquote {
margin:0 0 0 4px;}
#ygrps-yiv-565174160 #ygrps-yiv-565174160yiv4287617288 .ygrps-yiv-565174160yiv4287617288bold {
font-family:Arial;font-size:13px;font-weight:700;}
#ygrps-yiv-565174160 #ygrps-yiv-565174160yiv4287617288 .ygrps-yiv-565174160yiv4287617288bold a {
#ygrps-yiv-565174160 #ygrps-yiv-565174160yiv4287617288 dd.ygrps-yiv-565174160yiv4287617288last p a {
font-family:Verdana;font-weight:700;}
#ygrps-yiv-565174160 #ygrps-yiv-565174160yiv4287617288 dd.ygrps-yiv-565174160yiv4287617288last p span {
margin-right:10px;font-family:Verdana;font-weight:700;}
#ygrps-yiv-565174160 #ygrps-yiv-565174160yiv4287617288 dd.ygrps-yiv-565174160yiv4287617288last p span.ygrps-yiv-565174160yiv4287617288yshortcuts {
margin-right:0;}
#ygrps-yiv-565174160 #ygrps-yiv-565174160yiv4287617288 div.ygrps-yiv-565174160yiv4287617288attach-table div div a {
#ygrps-yiv-565174160 #ygrps-yiv-565174160yiv4287617288 div.ygrps-yiv-565174160yiv4287617288attach-table {
width:400px;}
#ygrps-yiv-565174160 #ygrps-yiv-565174160yiv4287617288 div.ygrps-yiv-565174160yiv4287617288file-title a, #ygrps-yiv-565174160 #ygrps-yiv-565174160yiv4287617288 div.ygrps-yiv-565174160yiv4287617288file-title a:active, #ygrps-yiv-565174160 #ygrps-yiv-565174160yiv4287617288 div.ygrps-yiv-565174160yiv4287617288file-title a:hover, #ygrps-yiv-565174160 #ygrps-yiv-565174160yiv4287617288 div.ygrps-yiv-565174160yiv4287617288file-title a:visited {
#ygrps-yiv-565174160 #ygrps-yiv-565174160yiv4287617288 div.ygrps-yiv-565174160yiv4287617288photo-title a, #ygrps-yiv-565174160 #ygrps-yiv-565174160yiv4287617288 div.ygrps-yiv-565174160yiv4287617288photo-title a:active, #ygrps-yiv-565174160 #ygrps-yiv-565174160yiv4287617288 div.ygrps-yiv-565174160yiv4287617288photo-title a:hover, #ygrps-yiv-565174160 #ygrps-yiv-565174160yiv4287617288 div.ygrps-yiv-565174160yiv4287617288photo-title a:visited {
#ygrps-yiv-565174160 #ygrps-yiv-565174160yiv4287617288 div#ygrps-yiv-565174160yiv4287617288ygrp-mlmsg #ygrps-yiv-565174160yiv4287617288ygrp-msg p a span.ygrps-yiv-565174160yiv4287617288yshortcuts {
font-family:Verdana;font-size:10px;font-weight:normal;}
#ygrps-yiv-565174160 #ygrps-yiv-565174160yiv4287617288 .ygrps-yiv-565174160yiv4287617288green {
color:#628c2a;}
#ygrps-yiv-565174160 #ygrps-yiv-565174160yiv4287617288 .ygrps-yiv-565174160yiv4287617288MsoNormal {
margin:0 0 0 0;}
#ygrps-yiv-565174160 #ygrps-yiv-565174160yiv4287617288 o {
font-size:0;}
#ygrps-yiv-565174160 #ygrps-yiv-565174160yiv4287617288 #ygrps-yiv-565174160yiv4287617288photos div {
float:left;width:72px;}
#ygrps-yiv-565174160 #ygrps-yiv-565174160yiv4287617288 #ygrps-yiv-565174160yiv4287617288photos div div {
border:1px solid #666666;height:62px;overflow:hidden;width:62px;}
#ygrps-yiv-565174160 #ygrps-yiv-565174160yiv4287617288 #ygrps-yiv-565174160yiv4287617288photos div label {
color:#666666;font-size:10px;overflow:hidden;text-align:center;white-space:nowrap;width:64px;}
#ygrps-yiv-565174160 #ygrps-yiv-565174160yiv4287617288 #ygrps-yiv-565174160yiv4287617288reco-category {
font-size:77%;}
#ygrps-yiv-565174160 #ygrps-yiv-565174160yiv4287617288 #ygrps-yiv-565174160yiv4287617288reco-desc {
font-size:77%;}
#ygrps-yiv-565174160 #ygrps-yiv-565174160yiv4287617288 .ygrps-yiv-565174160yiv4287617288replbq {
margin:4px;}
#ygrps-yiv-565174160 #ygrps-yiv-565174160yiv4287617288 #ygrps-yiv-565174160yiv4287617288ygrp-actbar div a:first-child {
margin-right:2px;padding-right:5px;}
#ygrps-yiv-565174160 #ygrps-yiv-565174160yiv4287617288 #ygrps-yiv-565174160yiv4287617288ygrp-mlmsg {
font-size:13px;font-family:Arial, helvetica, clean, sans-serif;}
#ygrps-yiv-565174160 #ygrps-yiv-565174160yiv4287617288 #ygrps-yiv-565174160yiv4287617288ygrp-mlmsg table {
font-size:inherit;font:100%;}
#ygrps-yiv-565174160 #ygrps-yiv-565174160yiv4287617288 #ygrps-yiv-565174160yiv4287617288ygrp-mlmsg select, #ygrps-yiv-565174160 #ygrps-yiv-565174160yiv4287617288 input, #ygrps-yiv-565174160 #ygrps-yiv-565174160yiv4287617288 textarea {
font:99% Arial, Helvetica, clean, sans-serif;}
#ygrps-yiv-565174160 #ygrps-yiv-565174160yiv4287617288 #ygrps-yiv-565174160yiv4287617288ygrp-mlmsg pre, #ygrps-yiv-565174160 #ygrps-yiv-565174160yiv4287617288 code {
font:115% monospace;}
#ygrps-yiv-565174160 #ygrps-yiv-565174160yiv4287617288 #ygrps-yiv-565174160yiv4287617288ygrp-mlmsg * {
line-height:1.22em;}
#ygrps-yiv-565174160 #ygrps-yiv-565174160yiv4287617288 #ygrps-yiv-565174160yiv4287617288ygrp-mlmsg #ygrps-yiv-565174160yiv4287617288logo {
padding-bottom:10px;}
#ygrps-yiv-565174160 #ygrps-yiv-565174160yiv4287617288 #ygrps-yiv-565174160yiv4287617288ygrp-msg p a {
font-family:Verdana;}
#ygrps-yiv-565174160 #ygrps-yiv-565174160yiv4287617288 #ygrps-yiv-565174160yiv4287617288ygrp-msg p#ygrps-yiv-565174160yiv4287617288attach-count span {
color:#1E66AE;font-weight:700;}
#ygrps-yiv-565174160 #ygrps-yiv-565174160yiv4287617288 #ygrps-yiv-565174160yiv4287617288ygrp-reco #ygrps-yiv-565174160yiv4287617288reco-head {
color:#ff7900;font-weight:700;}
#ygrps-yiv-565174160 #ygrps-yiv-565174160yiv4287617288 #ygrps-yiv-565174160yiv4287617288ygrp-reco {
margin-bottom:20px;padding:0px;}
#ygrps-yiv-565174160 #ygrps-yiv-565174160yiv4287617288 #ygrps-yiv-565174160yiv4287617288ygrp-sponsor #ygrps-yiv-565174160yiv4287617288ov li a {
font-size:130%;text-decoration:none;}
#ygrps-yiv-565174160 #ygrps-yiv-565174160yiv4287617288 #ygrps-yiv-565174160yiv4287617288ygrp-sponsor #ygrps-yiv-565174160yiv4287617288ov li {
font-size:77%;list-style-type:square;padding:6px 0;}
#ygrps-yiv-565174160 #ygrps-yiv-565174160yiv4287617288 #ygrps-yiv-565174160yiv4287617288ygrp-sponsor #ygrps-yiv-565174160yiv4287617288ov ul {
margin:0;padding:0 0 0 8px;}
#ygrps-yiv-565174160 #ygrps-yiv-565174160yiv4287617288 #ygrps-yiv-565174160yiv4287617288ygrp-text {
font-family:Georgia;}
#ygrps-yiv-565174160 #ygrps-yiv-565174160yiv4287617288 #ygrps-yiv-565174160yiv4287617288ygrp-text p {
margin:0 0 1em 0;}
#ygrps-yiv-565174160 #ygrps-yiv-565174160yiv4287617288 #ygrps-yiv-565174160yiv4287617288ygrp-text tt {
font-size:120%;}
#ygrps-yiv-565174160 #ygrps-yiv-565174160yiv4287617288 #ygrps-yiv-565174160yiv4287617288ygrp-vital ul li:last-child {
border-right:none !important;}
