Because of the need to loop thru multiple records in a Data Directive I can’t simply call the Automation Studio widget because I need a looping structure to call it multiple times.
My thought is to either use custom code in the directive or have the directive call a function.
I have the webhook url and required json parameters for the Automation Studio “recipe”.
Has anyone called Automation Studio via code and can provide an example ?
Thank you @aosemwengie1, I just got it working and was about to tweak my code to post it here, easier than I thought once I figured out which REST classes were available in the .Net libraries Epicor provides
