Calling a report process from VB
Did anyone get this figured out? I am trying to figure out how to get job parts to work and I think if I can get the print tags button on the job parts screen, I can maybe do it. I do not know VB or much about programming and how Vantage works behind the scenes, so if someone can explain in detail, I would appreciate it.
--- In vantage@yahoogroups.com, "bpbuechler" <pbuechler@...> wrote:
> We are struggling with the same thing.
> The oTrans and _Column seems to be declaring the default values that
> are not part of the transaction, but are required for the row to
> update the db.
> Any luck on your end?
> Thanks
> Patty Buechler
> --- In vantage@yahoogroups.com, "Michael McWilliams"
> <mmcwilliams22@> wrote:
> > The report that you are calling has multiple paramters that are
> > input based on the form that you are printing it from. RQ will pass
> > the launch form options to the MTLtags form. This report is not
> > only called from Report quantity screen. If you can figure out the
> > launch form options correctly for this report let me know. You
> first
> > have to notify the MTLtags form of what process is calling it &
> then
> > pass the correct parameters. I could not get it to work the right
> > way. I had it almost working the way I wanted by copying items to
> > the clipboard on the button click and then pasting them into the
> > fields on MTLtags after loading the form.
> > --- In vantage@yahoogroups.com, "greg.deterding"
> > <greg.deterding@> wrote:
> > > I'm trying to call the Print Tags report screen from a button in
> > MES
> > > Report Qty similar to the button that is already on there. I'm
> > using:
> > > ProcessCaller.LaunchForm(oTrans, "Epicor.Mfg.UIRpt.MtlTags")
> > > It will load but I'm getting an error: "Index was outside the
> > bounds
> > > of the array." Its also not passing the RQ.CurrentQty data to the
> > > ReportParam.QtyPer field which would be nice but not crucial.
> > > Is calling a report screen like this doable with a customization?
> > Any
> > > thought?
> > > thanks,
> > > Greg
> > > greg.deterding@
I'm trying to call the Print Tags report screen from a button in MES
Report Qty similar to the button that is already on there. I'm using:
It will load but I'm getting an error: "Index was outside the bounds
Is calling a report screen like this doable with a customization? Any
thought?
thanks,
Greg
greg.deterding@...
launch form options correctly for this report let me know. You first
have to notify the MTLtags form of what process is calling it & then
MES
using:
bounds
Any
> thought?
> thanks,
> Greg
> greg.deterding@...
update the db.
Patty Buechler
first
then
> MES
> using:
> bounds
> Any
> > thought?
> > thanks,
> > Greg
> > greg.deterding@
