I am still relatively new to Epicor and very new to this type of endeavor. I am trying to run/call a BAQ Report from a button click and am not sure how to accomplish this in my customization
My Report ID is SerialNumberLab
BAQ ID is BAQR_SerialNumbers
This is the code I have thus far inside my button click handler.
Ice.UI.Rpt.BAQReport.Transaction trans = new Ice.UI.Rpt.BAQReport.Transaction(oTrans);
Here is how we do it. There is a bit more here then just calling the report. You also need to set printer settings, which can be seen from the trace when calling the BAQ Report from the menu. (I am assuming that is how folks call it today)
private void printReport()
string[] printerInfo = GetDefaultPrinter(((Session)oTrans.Session).UserID);
string printer = printerInfo[0];
string pageSettings = printerInfo[1];
string printerSettings = printerInfo[2];
string agentID = "";
string strSerialNum = edvSerialNumDV.dataView[edvSerialNumDV.Row]["SerialNumber"].ToString();
try
Session otSession = (Session)oTrans.Session;
//Set the workstationID
string workStation = Ice.Lib.Report.EpiReportFunctions.GetWorkStationID(otSession);
//Get or Set the AgentID
using (var aSA = new SysAgentAdapter(oTrans))
aSA.BOConnect();
aSA.GetDefaultTaskAgentID(out agentID);
if (!string.IsNullOrEmpty(agentID)) { agentID = "SystemTaskAgent"; }
for (int i =0; i < 1; i++)
var baqR = WCFServiceSupport.CreateImpl<Ice.Proxy.Rpt.BAQReportImpl>((Session)oTrans.Session, Epicor.ServiceModel.Channels.ImplBase<Ice.Contracts.BAQReportSvcContract>.UriPath);
var dynamicReport = WCFServiceSupport.CreateImpl<Ice.Proxy.BO.DynamicReportImpl>((Session)oTrans.Session, Epicor.ServiceModel.Channels.ImplBase<Ice.Contracts.DynamicReportSvcContract>.UriPath);
// GET DEFAULT REPORT PARAMETERS
var rptDs = dynamicReport.GetByID("ETK_RMA_Trav");
var baqRptDS = baqR.GetNewBAQReportParam("ETK_RMA_Trav");
baqRptDS.BAQReportParam[0].Option01 = strSerialNum;
baqRptDS.BAQReportParam[0].AutoAction = "SSRSClientPrint";
baqRptDS.BAQReportParam[0].WorkstationID = workStation;
baqRptDS.BAQReportParam[0].PrinterName = printer;
baqRptDS.BAQReportParam[0].RptPageSettings = pageSettings;
baqRptDS.BAQReportParam[0].RptPrinterSettings = printerSettings;
baqRptDS.BAQReportParam[0].SSRSRenderFormat = "PDF";
baqRptDS.BAQReportParam[0].BAQRptID = "ETK_RMA_Trav";
baqRptDS.BAQReportParam[0].ReportID = "ETK_RMA_Trav";
baqRptDS.BAQReportParam[0].Summary = false;
baqRptDS.BAQReportParam[0].ReportStyleNum = 1;
baqRptDS.BAQReportParam[0].BAQID = "ETK_RMA_Trav";
baqRptDS.BAQReportParam[0].ReportTitle = "Depot RMA Traveller";
rptDs.BAQRptOptionFld[0].FieldValue = strSerialNum;
rptDs.AcceptChanges();
StringWriter writer = new StringWriter();
rptDs.WriteXml(writer);
baqRptDS.BAQReportParam[0].Filter1 = writer.ToString();
baqR.SubmitToAgent(baqRptDS, agentID, 0, 0, "Erp.UIRpt.BAQReport");
catch (Exception ex)
MessageBox.Show("An error occured trying to print report." + ex.Message);
