bmanners
(brett manners)
September 4, 2018, 12:25pm
1
I am trying to call the rest pi via a VBA macro in Solidworks but I am having some trouble. I can get the call to work in the Epicor rest web interface (https://SERVER/APPSERVER/api/help/methods/Ice.BO.UD02Svc/index#!/Custom_methods/GetaNewUD02 ). I can also get it to work in a c# console app. But i am forced to use VBA in the soldiworks macro and that is proving difficult.
Here is my code so far:
Dim jsonStr As String
jsonStr = "{""ds"":{ ""UD02"": [] }}"
Set objHTTP = CreateObject("MSXML2.ServerXMLHTTP")
URL = "https://SERVER/APPSERVER/api/v1/Ice.BO.UD02Svc/GetaNewUD02"
objHTTP.SetOption 2, 13056
objHTTP.Open "POST", URL, False
objHTTP.setRequestHeader "Content-type", "application/json"
objHTTP.setRequestHeader "Accept", "application/json"
objHTTP.setRequestHeader "User-Agent", "Mozilla/4.0 (compatible; MSIE 6.0; Windows NT 5.0)"
objHTTP.setRequestHeader "Authorization", "Basic " & "user" & ":" & "password"
objHTTP.send jsonStr
This gives an error with the message “The input is not a valid Base-64 string as it contains a non-base 64 character, more than two padding char”.
I have looked at plenty of posts online and tried many things but I am not getting anywhere.
Things i have tried
using a very simple string of “a”
various encoding methods found online to convert to byte array, base64 encoding etc
If anyone has any ideas it would be greatly appreciated…
Brett
josecgomez
(Jose C Gomez)
September 4, 2018, 12:43pm
2
The authorization header needs to be base 64 encoded… You are passing plain “user”:“password”
It should be
base64Encode(“user”:“password”) //Note not an actual function… just an example. looks like this isn’t built in to VBA… here’s an implementation
bmanners
(brett manners)
September 4, 2018, 1:11pm
3
Yep that was it. I was trying to encode the content instead of the auth string… I used one of the encoder functions i had and it worked.
here is the working code to make the rest call
objHTTP.SetOption 2, 13056 ' To ignore self signed cert errors
Dim auth As String
auth = "Basic " & TextBase64Encode("user" & ":" & "password", "ASCII")
objHTTP.setRequestHeader "Authorization", auth
And the TextBase64Encode from utf 8 - Encoding special chracters to Base64 in Excel VBA - Stack Overflow
Function TextBase64Encode(strText, strCharset)
Dim arrBytes
With CreateObject("ADODB.Stream")
.Type = 2 ' adTypeText
.Open
.Charset = strCharset
.WriteText strText
.Position = 0
.Type = 1 ' adTypeBinary
arrBytes = .Read
.Close
End With
With CreateObject("Microsoft.XMLDOM").createElement("tmp")
.dataType = "bin.base64"
.nodeTypedValue = arrBytes
TextBase64Encode = Replace(Replace(.Text, vbCr, ""), vbLf, "")
End With
End Function
