Hi, how to call function created in Function Maintenance in the configurator user defined methods?
much appreciated for all the inputs!
You can’t. My suggestion is marked future consideration. https://epicor-manufacturing.ideas.aha.io/ideas/KNTC-I-2102
well, technically it CAN be done from the configurator if you have advanced C# editing available in the configurator. In c#, you can call external methods, and a function is an API that call be called.
I did it by calling the Epicor Function via the Epicor REST API using the RestSharp.dll
@timshuwy , can you elaborate on what you mean by “advanced C# editing”? Is that an option that needs to be turned on somewhere?
there is a flag in the user setup that allows for C# editing, but that is not available in some of our older instances of the cloud… so that is why I said “advanced”. if you don’t have this turned on, then it is not possible to write the C# code that you would need to enter to call the function.
