Call a BPM form via Custom Code?
Is it possible to call a BPM form from a custom code block? If so, what’s the correct syntax?
Yes, however it is a lot easier to have a Custom Code Block (check some stuff ) IF TRUE, ThenCall BPM Form (widget) then Run some more custom code.
Also more upgrade friendly.
How would you do it in code?
Like if you needed debugging info inside a For loop. This would really be for debugging during development of the BPM custom code.
And I’d rather use log files.
Something like this
this.BpmDataFormProcess("Close Order Rsn");
or this
if(this.BpmDataFormCanProcessImmediately("Close Order Rsn", true))
                    return this.BpmDataFormProcess("Close Order Rsn");
