Calculation Field Issues
Hey all,
I’m not sure why my syntax isn’t working as it’s correct… I am missing something?
(case when (OrderHed.ShipToNum) is null then 'Default Address' else OrderHed.ShipToNum end)
COALESCE(OrderHed.ShipToNum, 'Default Address')
Any ideas?
Both return nothing apart from the ShipToNum if there is one…
Have you tried empty string?
How do you mean?
This is with
ISNULL(TABLE.NAME, 'Default Address')
:confused:
(case
    'Default Address'
  when OrderHed.ShipToNum == '' then
    'Default Address'
  else
    OrderHed.ShipToNum
end)
edit
And I’m pretty sure that OrderHed.ShipToNum will never be null. It may be the empty string ("") as @Banderson mentioned.
