I am having a similar problem in E9. Demand does not calculate correctly in the PartQty, PartBin, and PartWhse tables, so I need to join OrderRel, filter just the Buy Direct demand, and subract it from the Demand in the tables to get the correct number, however the BAQ does not let you calculate on the null field (Demand - My Calculation) - for the null fields it remains null after the calculation. If anyone has figured this out it would be a great help.
--- In vantage@yahoogroups.com, Ephraim Feldman <effgroups@...> wrote:
> I tried it and it didnt work the analyze gave me a error
> On Thu, Apr 15, 2010 at 12:32 PM, Steven Gotschall <sgotschall@...>wrote:
> > I sometimes have problems using ?(null) in a BAQ calculation. Try comparing
> > to sqrt(-1), which returns a null.
> > On Thu Apr 15th, 2010 1:57 AM EDT efyf_1999 wrote:
> > >Hi All
> > >I was working with calculation fields in BAQ and tried to do a sort field
> > by combining a few values one of them a date vaule that was sometimes a NULL
> > and so i had to do a IF to eliminate the NULL but it gave me a compile
> > error.
> > >Also i was trying to do a calculation field on another calculation field
> > that was based on a sumarised table and it always gave me back a zero value.
> > >Can someone help me out with what is acceptable and what not in the
> > calculation field.
> > >Ephraim Feldman
