Start your counter at 0.
Scott
ï Conserve our resources. Please don't print this e-mail unless it's really necessary.
vantage@yahoogroups.com [mailto:
vantage@yahoogroups.com] On Behalf Of drew.pete
Sent: Monday, August 17, 2009 11:28 AM
To:
Subject: [Vantage] Calculating Total Shipped Qty
I am currently trying to sum up the field ShipDtl.SellingShipmentQty for the packing slip and dumping that summed value in ShipHead.Number02. I am new to vb so I'm learning as I go. I initialize the code upon the ShipHead.PackNum field change. I don't get any errors thrown but the value that appears in the ShipHead.Number02 field is 0. I'm guessing it is not storing my calculation. Any thoughts?
Drew
Private Sub ShipHead_AfterFieldChange(ByVal sender As object, ByVal args As DataColumnChangeEventArgs) Handles ShipHead_Column.ColumnChanged
Select Case args.Column.ColumnName
Case "PackNum"
'On Error Resume Next
Dim tempTotalShipped As Decimal = 6
Dim counter As integer = 1
Dim edvPackingLine As EpiDataView = CType(oTrans.EpiDataViews("ShipDtl"), EpiDataView)
Dim PackingLine As Int32 = edvPackingLine.dataView(edvPackingLine.Row)("PackLine")
Dim edvSellShipQty As EpiDataView = CType(oTrans.EpiDataViews("ShipDtl"), EpiDataView)
Dim SellShipQty As Decimal = edvSellShipQty.dataView(edvSellShipQty.Row) ("SellingShipmentQty")
Dim edvTotalQtyShipped As EpiDataView = CType(oTrans.EpiDataViews("ShipHead"), EpiDataView)
Dim TotalQtyShipped As Decimal = edvTotalQtyShipped.dataView(edvTotalQtyShipped.Row)("Number02")
while(counter <= PackingLine)
tempTotalShipped = tempTotalShipped + SellShipQty
counter = counter + 1
End while
TotalQtyShipped = tempTotalShipped
otrans.Update()
Case Else
End Select
End Sub
(1) To access the Files Section of our Yahoo!Group for Report Builder and Crystal Reports and other 'goodies', please goto:
