For example, I have a calculated field 'X' and 'Y'. In the X field it has a IFF statement. If that statement is true then I would like it to assign 'Y' a new value.
Is this possible?
Jasper
iff statements with only one calculated field.
Otherwise, Make the value of Y iif(x,new value,old calculated value).
Does this make sense?
Aaron Hoyt
Hittite Microwave
Sent: Wednesday, September 29, 2004 3:51 PM
To: Vantage Groups (E-mail)
Subject: [Vantage] Calculated Field
Is it possible to have a calculated field that assigns a value
to another calculated field.
Is this possible?
Jasper
Useful links for the Yahoo!Groups Vantage Board are: ( Note:
You must have already linked your email address to a yahoo id to enable
access. )
(1) To access the Files Section of our Yahoo!Group for Report
Builder and Crystal Reports and other 'goodies', please goto:
Yahoo! Groups Sponsor
ADVERTISEMENT
click here
<http://us.ard.yahoo.com/SIG=1291opfl7/M=295196.4901138.6071305.3001176/
D=groups/S=1705007183:HM/EXP=1096573883/A=2128215/R=0/SIG=10se96mf6/*htt
p://companion.yahoo.com>
<http://us.adserver.yahoo.com/l?M=295196.4901138.6071305.3001176/D=group
s/S=:HM/A=2128215/rand=768141557>
Yahoo! Groups Links
* Your use of Yahoo! Groups is subject to the Yahoo! Terms
of Service <http://docs.yahoo.com/info/terms/> .
Example below from Crystal help
This formula groups the number of Oscar nominations a movie received into
low, medium, high or extreme categories and in the process, shows some of
the possibilities for the expression lists following the Case labels:
BM_147518//Select example 2
BM_147519Select {movie.NOM}
BM_147520 Case 1,2,3, Is < 1 :
BM_147521 (
BM_147522 //Can have expression lists by using
BM_147523 //parentheses
BM_147524 10 + 20;
BM_147525 "low"
BM_147526 )
BM_147527 Case 4 To 6, 7, 8, 9 :
BM_147528 "medium"
BM_147529 Case 10 :
BM_147530 "high"
BM_147531 Default :
BM_147532 "extreme"
Dan Shallbetter
States Electric Mfg.
Sent: Wednesday, September 29, 2004 2:59 PM
Subject: RE: [Vantage] Calculated Field
Depending on where you are doing this, you should be able to use nested
Aaron Hoyt
Hittite Microwave
Is this possible?
Jasper
Sent: Wednesday, September 29, 2004 3:59 PM
Aaron Hoyt
Hittite Microwave
Is this possible?
Jasper
access. )
ADVERTISEMENT
click here
Yahoo! Groups Links
Yahoo! Groups Links
some hidden code? Please ignore the BM_147??? fields.
I will now go to my corner.
Dan Shallbetter
Sent: Wednesday, September 29, 2004 3:12 PM
To: 'vantage@yahoogroups.com'
If your working in Crystal you might be able to use a case statement.
BM_147521 (
BM_147524 10 + 20;
BM_147525 "low"
BM_147526 )
BM_147528 "medium"
BM_147529 Case 10 :
BM_147530 "high"
BM_147531 Default :
BM_147532 "extreme"
Dan Shallbetter
Aaron Hoyt
Hittite Microwave
Is this possible?
Jasper
Can you provide an example of the statement in 'X'? With that I can be
a little more clear.
Aaron
Sent: Wednesday, September 29, 2004 4:12 PM
I'm a little lost.
nested
value).
Aaron Hoyt
Hittite Microwave
value
the X
would
Is this possible?
Jasper
Note:
enable
access. )
Report
goto:
ADVERTISEMENT
click here
Yahoo! Groups Links
Terms
access. )
Yahoo! Groups Links
access. )
ADVERTISEMENT
click here
<http://us.ard.yahoo.com/SIG=129ds19lh/M=295196.4901138.6071305.3001176/
D=groups/S=1705007183:HM/EXP=1096575143/A=2128215/R=0/SIG=10se96mf6/*htt
s/S=:HM/A=2128215/rand=659233928>
Yahoo! Groups Links
Ok, I am not an expert with writting these, however I eventually get them to work. The syntax below is working for me, however I am trying to get "Late" to show up when ShipDtl.ShipCmpl <> True. Instead, I get '30000'. I can live with this and move on. I am really just wondering why I can't get the word "Late" to list. If I do insert "Late" in place of '00000', '10000', '20000', or '30000' the field is blank
IF ShipDtl.ShipCmpl = True
THEN
IF OrderRel.ReqDate <> OrderRel.NeedByDate
THEN ShipHead.ShipDate - OrderRel.NeedByDate
ELSE
THEN
IF OrderRel.ReqDate = OrderRel.NeedByDate
ELSE
IF ShipDtl.ShipCmpl <> True
THEN '00000'
ELSE '10000'
ELSE '20000'
Else '30000'
that makes a difference.
Ross
jplehr
Sent: Thursday, September 10, 2009 2:50 PM
Vantage 8.03.408A
THEN
ELSE
THEN
ELSE
THEN '00000'
ELSE '10000'
ELSE '20000'
Else '30000'
Jeff
--- In vantage@yahoogroups.com, "Ross Hughes" <ross.hughes@...> wrote:
> Is the calculated field data type CHARACTER? If not, try that and see if
> Ross
> jplehr
> Vantage 8.03.408A
> THEN
> ELSE
> THEN
> ELSE
> THEN '00000'
> ELSE '10000'
> ELSE '20000'
> Else '30000'
THEN
THEN STRING(ShipHead.ShipDate - OrderRel.NeedByDate)
ELSE
THEN
ELSE
THEN '00000'
ELSE '10000'
ELSE '20000'
Else 'LATE'
Sent: Thursday, September 10, 2009 4:05:11 PM
Subject: [Vantage] Re: Calculated Field
Â
Yes, it is CHARACTER. I have tried other combinations just in case.
Jeff
> Ross
> From: vantage@yahoogroups .com [mailto:vantage@yahoogroups .com] On Behalf Of
> jplehr
> To: vantage@yahoogroups .com
> Vantage 8.03.408A
> THEN
> ELSE
> THEN
> ELSE
> THEN '00000'
> ELSE '10000'
> ELSE '20000'
> Else '30000'
> http://groups. yahoo.com/ group/vantage/ files/.
> http://groups. yahoo.com/ group/vantage/ messages
> http://groups. yahoo.com/ group/vantage/ linksYahoo! Groups Links
I appreciate the help.
Jeff
--- In vantage@yahoogroups.com, Steven Gotschall <sgotschall@...> wrote:
> I think I see the problem, the very first "Then" returns the difference between two dates. The system is now expecting a number to be returned and even though you have set the field to character, it still wants a number returned which it will then convert to character. Since 'LATE' can not be converted to a number, the end result is a null or empty string. Try this instead:
> THEN
> ELSE
> THEN
> ELSE
> THEN '00000'
> ELSE '10000'
> ELSE '20000'
> Else 'LATE'
> From: jplehr <jlehr@...>
> Â
> Jeff
> > Ross
> > jplehr
> > Vantage 8.03.408A
> > THEN
> > ELSE
> > THEN
> > ELSE
> > THEN '00000'
> > ELSE '10000'
> > ELSE '20000'
> > Else '30000'
You can try:
DATEADD (day, 1, yourdate)
Brenda
Sent: Monday, December 21, 2015 11:25 AM
To: yahoogroups
I need to create a calculated field in a BAQ. I need to take a date field and add days to it. But I don't know if I can just do that or need special formatting.
These are from an answerbook on baq calculations.
Greg
Example # 7: To subtract two date fields you need to convert them to integers first. Note: for this example, set the data type to integer and the format to
>>>,>>9.
(integer(ShipHead.ShipDate) - integer(OrderRel.ReqDate))
Example # 6: To create a MonthYear field. You will need use both a concatenation and a string function. To do a concatenation use the + symbol. Use the string as the "outer function. Note: for this example you must set the data type to Character and the format to X(7).
string(Month(OrderHed.OrderDate), "99") + "-" + string(Year(OrderHed.OrderDate), "9999")
***For SQL where you want to display the Period use this syntax:
entry( Month(OrderHed.OrderDate),'01,02,03,04,05,06,07,08,09,10,11,12', ',') + "-" + tring(Year(OrderHed.OrderDate), "9999")
Example # 6.1: How to change format of Todays date to MMDDYYYY
String( Month(Today),"99") + "/" + String( Day(Today),"99") + "/" + string(Year(Today),"9999" )
- data type is character, format is x(10)
Example 6.2: How to change Todays date to format YYYMMDD
string(Year(Today),"9999" ) + "/" + String( Month(Today),"99") + "/" + String( Day(Today),"99")
To: yahoogroups
CONFIDENTIALITY NOTICE
The information contained in this communication, including attachments, is privileged and confidential. It is intended only for the exclusive use of the addressee. If the reader of this message is not the intended recipient, or the employee or agent responsible for delivering it to the intended recipient, you are hereby notified that any dissemination, distribution or copying of this communication is strictly prohibited. If you have received this communication in error, please notify us at 727-578-6240 and immediately delete the communication.
