OK, I keep getting a syntax error and need someone to point out what I am missing…
Thanks in advance.
Brad
Thanks in advance.
Brad
See where it says Case DaysLate remove the DaysLate after the word Case
Thanks!! I figured it was something simple.
Sometimes we all need a second eye I also tend to indent mine for easier reading
CASE
WHEN TotalTagsOpen = 0 THEN ''
WHEN (CCHdr.CycleStatus <> 0 AND CCHdr.CycleStatus <> 7) AND TotalTagsOpen <> TotalTagsReturned THEN 'Unreturned'
WHEN (CCHdr.CycleStatus <> 0 AND CCHdr.CycleStatus <> 7) AND TotalTagsOpen = TotalTagsReturned THEN 'Returned'
ELSE ''
END
CASE WHEN CCTag.FrozenQOH <> 0 THEN
((CCTag.CountedQty - TotalFrozenQOH) / IIF(CCTag.FrozenQOH <> 0, ABS(CCTag.FrozenQOH), 1)) * 100
ELSE 0
END
Also sometimes I create a few additional Calculated Fields then I can re-use them in several fields like in your case you could make a field called ReqDueDateDiff and do the entire datediff in there and then check the ReqDueDateDiff field in your CASE - but thats if you plan to create a few more calculated fields that may require checking the difference.
