Hi,
I want to calculate charge amount in Sales Order>Order Misc Charges based on 2 UD fields that I’ve created Price & Quantity, on lost focus event of Quantity cell.
Any help will be highly appreciated.
Thanks.
Hi,
Thanks.
Try the following on a customization of the Order Entry form:
public EpiUltraGrid grdHeadMiscChrg;
to the public class Script{...}
section.grdHeadMiscChrg = (EpiUltraGrid)csm.GetNativeControlReference("72e8dbae-9bf8-4a5d-80a1-076d1bbf3d6f");
to the InitialzeCustomCode
functionthis.grdHeadMiscChrg.AfterCellUpdate += new Infragistics.Win.UltraWinGrid.CellEventHandler(this.grdHeadMiscChrg_AfterCellUpdate);
right after the line added in step 2.this.grdHeadMiscChrg.AfterCellUpdate -= new Infragistics.Win.UltraWinGrid.CellEventHandler(this.grdHeadMiscChrg_AfterCellUpdate); to the
DestroyCustomCode` functionprivate void grdHeadMiscChrg_AfterCellUpdate(object sender, Infragistics.Win.UltraWinGrid.CellEventArgs args)
, and place your code in there.Here’s the whole Code of an example that shows a message box after leaving a cell (tha has been changed) in that grid.
// Custom code for SalesOrderForm
// Created: 1/2/2020 9:02:08 AM
extern alias Erp_Contracts_BO_AlternatePart;
extern alias Erp_Contracts_BO_SalesOrder;
extern alias Erp_Contracts_BO_Quote;
extern alias Erp_Contracts_BO_Part;
extern alias Erp_Contracts_BO_Customer;
extern alias Erp_Contracts_BO_RMAProc;
extern alias Erp_Contracts_BO_OrderDtlSearch;
extern alias Erp_Contracts_BO_OrderHist;
extern alias Erp_Contracts_BO_QuoteDtlSearch;
extern alias Erp_Contracts_BO_SerialNumberSearch;
extern alias Erp_Contracts_BO_ShipTo;
using System;
using System.ComponentModel;
using System.Data;
using System.Diagnostics;
using System.Windows.Forms;
using Erp.Adapters;
using Erp.UI;
using Ice.Lib;
using Ice.Adapters;
using Ice.Lib.Customization;
using Ice.Lib.ExtendedProps;
using Ice.Lib.Framework;
using Ice.Lib.Searches;
using Ice.UI.FormFunctions;
public class Script
// Begin Custom Code Disposal
// End Custom Code Disposal
MessageBox.Show("Built-in Grid AfterCellUpdate");
You’ll need to add code to determine which cell was just changed.
Thanks alot Calvin for your time and consideration, code that you provided really helped me, it was like a stepping stone for this requirement.
Regards,
Faez
