C# Help with Adapter GetByID
Hi
Please can somebody put me out of my misery - I’ve tried multiple ways to get this working, and I give up!
Basically inside the method btnPrintPartLabel_Click, I would like to get data from the Part record. I wish to get the value from Part.EngPartCat_c and Part.EngPartSubCat_c. With current code, I get no errors on compile or runtime but the sCategory variable always remains blank.
Many Thanks
Mark
// Custom code for InventoryQtyAdjustForm
// Created: 18/08/2017 14:39:46
using System;
using System.ComponentModel;
using System.Data;
using System.Diagnostics;
using System.Windows.Forms;
using Erp.Adapters;
using Erp.UI;
using Ice.Lib;
using Ice.Adapters;
using Ice.Lib.Customization;
using Ice.Lib.ExtendedProps;
using Ice.Lib.Framework;
using Ice.Lib.Searches;
using Ice.UI.FormFunctions;
using Erp.BO;
using Ice.BO;
using System.Text;
public class Script
// ** Wizard Insert Location - Do Not Remove ‘Begin/End Wizard Added Module Level Variables’ Comments! **
            private EpiDataView edvPart;
            private PartAdapter partAD ;
                            this.btnPrintBinLabel.Click += new System.EventHandler(this.btnPrintBinLabel_Click);
                            this.btnPrintPartLabel.Click += new System.EventHandler(this.btnPrintPartLabel_Click);
                            EpiDataView edvPart = ((EpiDataView)(this.oTrans.EpiDataViews["Part"]));
                            edvPart.dataView.Table.Columns.Add("Category");
                            edvPart.dataView.Table.Columns.Add("SubCategory", typeof(string));
                            //partAD = new PartAdapter( oTrans ) ;
                            //partAD.BOConnect() ;
                            this.btnPrintBinLabel.Click -= new System.EventHandler(this.btnPrintBinLabel_Click);
                            this.btnPrintPartLabel.Click -= new System.EventHandler(this.btnPrintPartLabel_Click);
                            // Begin Custom Code Disposal
                            this.edvPart = null;
                            //partAD.Dispose() ;
                            partAD = null ;
                            // End Custom Code Disposal
            private void btnPrintBinLabel_Click(object sender, System.EventArgs args)
                            string [] Lines = new string [4];
                            string FileName = string.Empty;
                            string LabelPrinter = "";
                            string LabelReport = "EngineeringBinLabel.btw";
                            string OutputPath = @"\\EpicorAPP01\BarTender\Commander\EngineeringBin\";
                            DateTime cNow = DateTime.Now;
                            EpiCombo cmbWhse = (EpiCombo)csm.GetNativeControlReference("17fd807c-51fc-431c-a72c-e300fb8208ac");
                            EpiTextBox txtBinNum = (EpiTextBox)csm.GetNativeControlReference("5a5538e6-53a1-4cc4-8de5-569c6b8e70c1");
                            EpiTextBox txtDescription = (EpiTextBox)csm.GetNativeControlReference("a030367f-9dbd-4b73-9efc-e39ef8628478");
                string sWhse = cmbWhse.Text;
                            string sBinNum = txtBinNum.Text;
                            string sDescription = txtDescription.Text;
                            if(sWhse != "Engineering Stock")
                               EpiMessageBox.Show("Only intended for Engineering Parts");
                                              return;
                            FileName = OutputPath + "EngBinLabel" + cNow.ToString ("_yyyy-MM-dd_HHmmss") + ".bt";
                            LabelPrinter = @"\\BV-PC-001\DYMO";
                            using (var OutFile = new System.IO.StreamWriter(new System.IO.FileStream(FileName,System.IO.FileMode.Create)))
                                            Lines[0] = "%BTW% ";
                                            Lines[0] = Lines [0] + "/AF=\"" ;
                                            Lines[0] = Lines [0] + @"\\epicorapp01\BarTender\Commander\EngineeringBin\" + LabelReport +"\"";
                                            Lines[0] = Lines [0] + @" /D=""<Trigger File Name>"" /PRN=";
                                            Lines[0] = Lines [0] +  "\"" + LabelPrinter + "\"";
                                            Lines[0] = Lines [0] + @" /DBTEXTHEADER=3 /R=3 /P";
                                            Lines[1] = "%END%";
                                            Lines[2] = "\"BinNum\",\"Description\"";
                                            StringBuilder sb = new StringBuilder();
                                            if (sBinNum.IndexOfAny(new char[] { '"', ',' }) != -1)
                                                            sb.AppendFormat("\"{0}\"", sBinNum.Replace("\"", "\"\""));
                                            else
                                                            sb.Append(sBinNum);
                                            sb.Append(",");
                                            if (sDescription.IndexOfAny(new char[] { '"', ',' }) != -1)
                                                            sb.AppendFormat("\"{0}\"", sDescription.Replace("\"", "\"\""));
                                            else
                                                            sb.Append(sDescription);
                                            Lines[3] = sb.ToString();
                                            OutFile.WriteLine(Lines[0]);
                                            OutFile.WriteLine(Lines[1]);
                                            OutFile.WriteLine(Lines[2]);
                                            OutFile.WriteLine(Lines[3]);
            private void btnPrintPartLabel_Click(object sender, System.EventArgs args)
                            string LabelReport = "EngineeringPartLabel.btw";
                            string OutputPath = @"\\EpicorAPP01\BarTender\Commander\EngineeringPart\";
                            EpiTextBox txtPartNum = (EpiTextBox)csm.GetNativeControlReference("138c27f2-8793-4d33-bb53-e1f5a753909a");
                            EpiTextBox txtDescription = (EpiTextBox)csm.GetNativeControlReference("f59e7876-bacd-4314-b354-bae4f83ebf9c");
                            string sPartNum = txtPartNum.Text;
                            string sCategory = string.Empty;
                            // Check if the Part is an Engineering part, if not then return
                            if(sPartNum.Length < 3)
                                              return;
                            string First3Letters = sPartNum.Substring(0, 3);
                            if(First3Letters != "ENG")
                                              return;
                            // Lookup Part Eng Category, and add into dataView
                             try
                                            partAD.ClearData() ;
                                             partAD.GetByID(sPartNum);
                                            edvPart.dataView[0]["Category"] = partAD.PartData.Part[0]["EngPartCat_c"] ;
                                              //sCategory = edvPart.dataView[0]["EngPartCat_c"].ToString();
                                              sCategory = partAD.PartData.Part[0]["AnalysisCode"].ToString();
                            catch (Exception ex)
                            partAD.Dispose() ;
                            partAD = null ;
                            EpiMessageBox.Show("cat = " + sCategory);
                            //EpiCombo txtCategory = (EpiCombo)csm.GetNativeControlReference("fc9a3fb0-dd3f-4d09-9d65-724d41f1c4e2");
                            //BAQCombo txtSubCategory = (BAQCombo)csm.GetNativeControlReference("50be7f9f-96ec-489c-8457-9f81078443ea");
                            //string sSubCategory = txtSubCategory.Text;
                            FileName = OutputPath + "EngPartLabel" + cNow.ToString ("_yyyy-MM-dd_HHmmss") + ".bt";
                            /*using (var OutFile = new System.IO.StreamWriter(new System.IO.FileStream(FileName,System.IO.FileMode.Create)))
                                            Lines[0] = Lines [0] + @"\\epicorapp01\BarTender\Commander\EngineeringPart\" + LabelReport +"\"";
                                            Lines[1] = "%END%";
                                            Lines[2] = "\"PartNum\",\"Description\",\"Category\",\"SubCategory\"";
                                            if (sPartNum.IndexOfAny(new char[] { '"', ',' }) != -1)
                                                            sb.AppendFormat("\"{0}\"", sPartNum.Replace("\"", "\"\""));
                                            else
                                                            sb.Append(sPartNum);
                                            sb.Append(",");
                                            else
                                            sb.Append(",");
                                            if (sCategory.IndexOfAny(new char[] { '"', ',' }) != -1)
                                                            sb.AppendFormat("\"{0}\"", sCategory.Replace("\"", "\"\""));
                                            else
                                                            sb.Append(sCategory);
                                            sb.Append(",");
                                            if (sSubCategory.IndexOfAny(new char[] { '"', ',' }) != -1)
                                                            sb.AppendFormat("\"{0}\"", sSubCategory.Replace("\"", "\"\""));
                                            else
                                                            sb.Append(sSubCategory);
In your code, you’re assuming that there is a valid value for the variable sPartNum and because you’re setting sCategory inside a try/catch, you won’t see any runtime errors when you pass in a bad value into your GetByID(sPartNum) method.
Thanks Aaron. You’ve moved my understanding along a bit. I have the PartAD lookup working now. Moved on to struggle with the Category lookup. I’m trying to lookup the CodeDesc from UDCodes.
Here is the code. The error is “There is now row a position 0” – which I take to mean that it hasn’t found a row. Is there something wrong with the DatasetMode, or parameters?
// Lookup Category Description from UserCodes
usercodeAD = new UserCodesAdapter( oTrans ) ;
usercodeAD.BOConnect() ;
                try
                               usercodeAD.ClearData() ;
                               bool morePages;
                               SearchOptions opts = new SearchOptions(SearchMode.AutoSearch);
                               opts.DataSetMode = DataSetMode.RowsDataSet;
                               opts.PageSize = 1; //return this many
                                              string whereCodeTypeID = string.Format("CodeTypeID = '{0}'", "ENGPARTCAT");
                                              string whereCodeID = string.Format("CodeID = '{0}'", sCatID);
                               opts.NamedSearch.WhereClauses.Add("UDCodeType", whereCodeTypeID);
                               opts.NamedSearch.WhereClauses.Add("UDCodes", whereCodeID);
                               usercodeAD.GetRows(opts, out morePages);
                               sCategory = usercodeAD.UserCodesData.UDCodes[0]["CodeDesc"].ToString();
                                              //MessageBox.Show(sCategory);
                                            MessageBox.Show("An error has occured - " + ex.Message);
                            finally
                                            usercodeAD.Dispose();
                                            usercodeAD = null;
I took the names of the whereClauses from the BL Tester:
[/uploads/default/original/2X/2/2c8842fa32f4c4dba13a88005988be9bac325217.png]
Many Thanks!
Can you try invoking a filter like this:
opts.PreLoadSearchFilter = String.Format(“CodeTypeID = ‘ENGPARTCAT’ and CodeID = ‘{0}’”, sCatID);
opts.DataSetMode=DataSetMode.RowsDataSet;
usercodeAD.InvokeSearch(opts);
I think this returns a data table…
Often times if I am trying to nail down a problem, I’ll simplify things. If possible, reduce your criteria down by one (for example codetype only). Also, like Aaron does in his example above, hardcode the codetype.
Finally, if you have VisualStudio - you can run the customization in DEBUG mode (click on the button on the bottom left of the customization select screen).
So, if I use the code you gave then it produces an error (the first bit, “An error has occurred” is from my exception handling):
[/uploads/default/original/2X/9/94c6810ec84cef60fc893557089ddfd7a0de6e96.png]
If I change it slightly, to the below code then I do get a data table returned, and I can access the CodeDesc. BUT, it’s always just the first code alphabetically within that CodeTypeID
opts.PreLoadSearchFilter = “CodeTypeID = ‘ENGPARTCAT’”;
sCategory = usercodeAD.UserCodesData.UDCodes[0][“CodeDesc”].ToString();
I know that it’s telling me it doesn’t understand the column name CodeID, but I can’t see why not!! That’s what the BL Tester shows!
So I can conclude that the InvokeSearch method is only returning CodeTypeID List - which is why it errors out when trying to select the CodeID column - this is similar to the method on the BL Tester called GetList.
I still don’t know why GetRows doesn’t work - on BL Tester it shows this:
GetRows(whereClauseCodeTypeID, whereClauseUDCodes, Int32 pageSize, Int32 absolutePage, out Boolean morePages). But, in C# coding it says no GetRows method takes 5 arguments. I would say that is not the case, as the BL Tester clearly shows it taking 5 arguments. On the BL Tester, I can provide where clauses in both CodeTypeID and UDCodes and it works perfectly returning a single row.
What I ended up getting to work, it overkill but see what you think:
    try
   	   bool morePages;
   	   opts.PageSize = 100; //return this many
   	   opts.PreLoadSearchFilter = "CodeTypeID = 'ENGPARTCAT'";
		  for (int i = 0; i < usercodeAD.UserCodesData.UDCodes.Count; i++)
              if (usercodeAD.UserCodesData.UDCodes[i]["CodeID"].ToString() == sCatID)
			  	 sCategory = usercodeAD.UserCodesData.UDCodes[i]["CodeDesc"].ToString();
			  	 break;
		MessageBox.Show("An error has occured: " + ex.Message);
	finally
		usercodeAD = null;
FYI, none of your pictures are uploading :slight_smile:
That’s definitely overkill for what you’re needing. Let me dig through my code and find out why this isn’t working for you. Stay tuned…
It’s because the call doesn’t have that format originally (i.e. it’s recalled )
// Ice.Adapters.UserCodesAdapter
protected override DataSet OnGetRows(SearchOptions opts, out bool MorePages, params string[] whereClauses)
	if (whereClauses.Length != 2)
		throw new TargetParameterCountException();
	return this.userCodesBO.GetRows(whereClauses[0], whereClauses[1], opts.PageSize, opts.AbsolutePage, out MorePages);
So it appears you must have those 2 where clauses added to a SearchOpts object (like you’ve done before)
                 bool more = false;
                 DataSet YourResult = usercodeAD.GetRows(opts, out more);  /* CALLING IT */
Also note it appears to returns a DataSet - You can crawl through it and get what you want:
foreach(DataRow row in YourResult.Tables[0].Rows)
    MessagBox.Show(row["AValidColumnName"].ToString() );
However it seems like you only expect one result - maybe throw an error if YourResult.Tables[0].Rows.Count != 1
Ok this one is tricky, so I’m not surprised we are having issues.
Try this code:
  bool morePages = false;
  UserCodesAdapter adapterUserCodes = new UserCodesAdapter(oTrans);
  adapterUserCodes.BOConnect();
  string whereClause = "Your WhereClause Here";
  opts.NamedSearch.WhereClauses.Add("UDCodes", whereClause);
  DataSet dsUserCodes = adapterUserCodes.GetRows(opts, out morePages);
  if(dsUserCodes.Tables[0].Rows.Count>0)
  	MessageBox.Show("DataSet: " + dsUserCodes.Tables[0].Rows.Count.ToString());
  adapterUserCodes.Dispose();
I noticed from debugging that the adapter data doesn’t get filled out with the GetRows call. Instead, I threw the results into a dataset and used that dataset to pull data from.
But you have to ensure you send it both whereclauses or it wont work. See above.
Yup, that’l do it. hasbtable and subtable search for this one. failrly standerized code.
Thanks for all the help on this, another great example of the amazing knowledge and willingness to share it on this forum!
But the million dollar question is - Did it work? :joy: NM - I see the solution mark. Awesome!
