Button On native Ultragrid Dashboard
I have created a custom grid on our dashboard and able to get he button to show up am unable to get the buttons to show up on the data grid in my dashboard. Any one able to help me get this working on the native grid.
Thank you.
// Custom code for MainController
// Created: 4/23/2021 11:21:27 AM
using System;
using System.ComponentModel;
using System.Data;
using System.Diagnostics;
using System.Windows.Forms;
using Ice.BO;
using Ice.UI;
using Ice.Lib;
using Ice.Adapters;
using Ice.Lib.Customization;
using Ice.Lib.ExtendedProps;
using Ice.Lib.Framework;
using Ice.Lib.Searches;
using Ice.UI.FormFunctions;
using Infragistics.Win.UltraWinGrid;
using System.Collections.Generic;
using Ice.Core;
public class Script
	EpiUltraGrid ugQuoteHeader;
		this.ClearFilters.Click += new System.EventHandler(this.ClearFilters_Click);
		this.btnCustomerFilter.Click += new System.EventHandler(this.btnCustomerFilter_Click);
		this.ugQuoteHeader =(EpiUltraGrid)csm.GetNativeControlReference("598c6b70-6cba-4b4a-9755-243fcd8e2925");
		this.ugQuoteHeader.DisplayLayout.Bands[0].Columns["Calculated_Button"].Style = Infragistics.Win.UltraWinGrid.ColumnStyle.Button;
		this.ugQuoteHeader.DisplayLayout.Bands[0].Columns["Calculated_Button"].ButtonDisplayStyle = Infragistics.Win.UltraWinGrid.ButtonDisplayStyle.Always;
		this.ugQuoteHeader.ClickCellButton += new Infragistics.Win.UltraWinGrid.CellEventHandler(this.ugQuoteHeader_ClickCellButton);
		this.ugQuoteHeaders.DisplayLayout.Bands[0].Columns.Add("HubSpot");
		this.ugQuoteHeaders.DisplayLayout.Bands[0].Columns["HubSpot"].Style = Infragistics.Win.UltraWinGrid.ColumnStyle.Button;
		this.ugQuoteHeaders.DisplayLayout.Bands[0].Columns["HubSpot"].ButtonDisplayStyle = Infragistics.Win.UltraWinGrid.ButtonDisplayStyle.Always;
		this.ugQuoteHeaders.ClickCellButton += new Infragistics.Win.UltraWinGrid.CellEventHandler(this.ugQuoteHeaders_ClickCellButton);
		this.ClearFilters.Click -= new System.EventHandler(this.ClearFilters_Click);
		this.btnCustomerFilter.Click -= new System.EventHandler(this.btnCustomerFilter_Click);
		this.ugQuoteHeaders.ClickCellButton -= new Infragistics.Win.UltraWinGrid.CellEventHandler(this.ugQuoteHeaders_ClickCellButton);
		this.ugQuoteHeader.ClickCellButton -= new Infragistics.Win.UltraWinGrid.CellEventHandler(this.ugQuoteHeader_ClickCellButton);
		// Begin Custom Code Disposal
		// End Custom Code Disposal
	private void ClearFilters_Click(object sender, System.EventArgs args)
		Ice.Lib.Framework.EpiBasePanel pnl = (Ice.Lib.Framework.EpiBasePanel)csm.GetNativeControlReference("9fc6a346-e062-4c54-a790-6e37882f4463");
		EpiUltraCombo closedQuote = (EpiUltraCombo)csm.GetNativeControlReference("4b5ff17c-1d71-42df-9700-a3e4a997aa5b");
		EpiUltraCombo hasPO = (EpiUltraCombo)csm.GetNativeControlReference("e693b2c2-81a3-414b-b64e-89ed0b1efc6e");
        foreach (Control c in pnl.Controls)
            if (c.GetType() == typeof(EpiTextBox))
                c.Text = string.Empty;
            if (c.GetType() == typeof(EpiNumericEditor))
                ((EpiNumericEditor)c).Value = null;
            if (c.GetType() == typeof(EpiCombo))
            if (c.GetType() == typeof(EpiDateTimeEditor))
            if (c.GetType() == typeof(EpiTimeEditor))
		closedQuote.Text = string.Empty;
		hasPO.Text = string.Empty;
	private void btnCustomerFilter_Click(object sender, System.EventArgs args)
		SearchOnCustomerAdapterShowDialog();
	private void SearchOnCustomerAdapterShowDialog()
		// Wizard Generated Search Method
		// You will need to call this method from another method in custom code
		// For example, [Form]_Load or [Button]_Click
		EpiTextBox customer;
		customer = (EpiTextBox)csm.GetNativeControlReference("9ed9ba42-1573-41ff-a6b0-e0b58cca8eaf");
		bool recSelected;
		string whereClause = string.Empty;
		System.Data.DataSet dsCustomerAdapter = Ice.UI.FormFunctions.SearchFunctions.listLookup(this.oTrans, "CustomerAdapter", out recSelected, true, whereClause);
		if (recSelected)
			System.Data.DataRow adapterRow = dsCustomerAdapter.Tables[0].Rows[0];
			// Map Search Fields to Application Fields
			EpiDataView edvV_QuoteTracking_1View = ((EpiDataView)(this.oTrans.EpiDataViews["V_QuoteTracking_1View"]));
			System.Data.DataRow edvV_QuoteTracking_1ViewRow = edvV_QuoteTracking_1View.CurrentDataRow;
			if ((edvV_QuoteTracking_1ViewRow != null))
				edvV_QuoteTracking_1ViewRow.BeginEdit();
				edvV_QuoteTracking_1ViewRow["Customer_CustID"] = adapterRow["CustID"];
				edvV_QuoteTracking_1ViewRow.EndEdit();
			System.Data.DataRow adapterRow1 = dsCustomerAdapter.Tables[0].Rows[0];
			customer.Text = adapterRow1["CustID"].ToString();
	private void ugQuoteHeaders_ClickCellButton(object sender, Infragistics.Win.UltraWinGrid.CellEventArgs args)
		string companyName = oTrans.CoreSession.CompanyName;
		string instanceProd = "";
		string instanceTest = "";
		string instance = "";
		string [] urlArr;
		string url;
		urlArr = new string[5];
		foreach(var row in ugQuoteHeaders.Rows)
			if(row.Activated)
					if(companyName.ToLower().Contains("test"))
						instanceTest = "20935426";
						instance = instanceTest;
					else
						instanceProd = "532305";
						instance = instanceProd;
					        urlArr[0] = "https://app.hubspot.com";
					        urlArr[1] = "/contacts/";
					        urlArr[2] = instance;
					       urlArr[3] = "/deal/";
					       urlArr[4] = row.Cells["QuoteHed_HSDealID_c"].Value.ToString();
					       url = string.Join ("",urlArr);
					      //MessageBox.Show(url,"test");
					      Process.Start(url);
					     MessageBox.Show(row.Cells["QuoteHed_HSDealID_c"].Value.ToString());
					      MessageBox.Show("Dont Touch Me There","EWWWWW");
	private void ugQuoteHeader_ClickCellButton(object sender, Infragistics.Win.UltraWinGrid.CellEventArgs args)
