Button "file, new"
I assume when you're talking about adding a "file,new" button you're in data entry A/P invoice entry, for example. So, what I've done is added hot keys to those forms. For example, Ctrl+I for a new invoice, Ctrl+L for a new line and so forth. Hot keys are activated under the Tools, then Options drop down lists and are available in most data entry input screens.
--- In vantage@yahoogroups.com, "cooner_55421" <cooner_55421@...> wrote:
> > No idea what you mean.
> Just that sometimes it feels like lot's of menu selections for an operation.
> My best example would probably be printing a label when I finish an operation in MES.
> > *Jose C Gomez*
> > *Software Engineer*
> > *T: 904.469.1524 mobile
> > E: jose@
> > http://www.josecgomez.com
> > <http://www.linkedin.com/in/josecgomez> <http://www.facebook.com/josegomez>
> > <http://www.google.com/profiles/jose.gomez> <http://www.twitter.com/joc85>
> > <http://www.josecgomez.com/professional-resume/>
> > <http://www.josecgomez.com/feed/>
> > *Quis custodiet ipsos custodes?*
> > On Tue, Apr 12, 2011 at 2:57 PM, cooner_55421 <cooner_55421@>wrote:
> > > Thanks for the example.
> > > BTW...
> > > Now I'm wondering why I couldn't find very many examples for buttons.
> > > It seemed like a good way to reduce steps.
> > > Am I out in left field?
> > > Vantage sometimes feels a little too "clicky" to me.
> > > > Basically you need to hookup to the current Adapter and call
> > > > the get-anew method on it.
> > > > something like
> > > > UD10Adapter oTrans_adapter;
> > > > oTrans_adapter = (UD10Adapter)csm.TransAdaptersHT["oTrans_adapter"];
> > > > if (oTrans_adapter.GetaNewUD10())
> > > > // Get unique row count id for Key5
> > > > int rowCnt = 0;
> > > > int lineNum;
> > > > rowCnt = oTrans_adapter.UD10Data.UD10.Rows.Count;
> > > > lineNum = rowCnt;
> > > > bool goodIdx = false;
> > > > // ** determine Key5 value
> > > > while (!goodIdx)
> > > > // Check to see if index exists
> > > > System.Data.DataRow[] drs = oTrans_adapter.UD10Data.UD10.Select("Key5 =
> > > > + lineNum.ToString() + "'");
> > > > if (drs.Length > 0)
> > > > lineNum++;
> > > > else
> > > > goodIdx = true;
> > > > // Set initial UD Key values
> > > > int numRow = (rowCnt - 1);
> > > > oTrans_adapter.UD10Data.UD10.Rows[numRow].BeginEdit();
> > > > oTrans_adapter.UD10Data.UD10.Rows[numRow]["Key1"] = "your key1";
> > > > oTrans_adapter.UD10Data.UD10.Rows[numRow]["Key2"] = "your key2";
> > > > oTrans_adapter.UD10Data.UD10.Rows[numRow]["Key3"] = String.Empty;
> > > > oTrans_adapter.UD10Data.UD10.Rows[numRow]["Key4"] = String.Empty;
> > > > oTrans_adapter.UD10Data.UD10.Rows[numRow]["Key5"] = lineNum.ToString();
> > > > oTrans_adapter.UD10Data.UD10.Rows[numRow].EndEdit();
> > > > // Notify with updated data
> > > > _edvUD10.Notify(new EpiNotifyArgs(oTrans, numRow, _edvUD10.Column));
> > > > *Jose C Gomez*
> > > > *Software Engineer*
> > > > E: jose@
> > > > On Tue, Apr 12, 2011 at 2:30 PM, cooner_55421 <cooner_55421@>wrote:
> > > > > BTW..
> > > > > I ran a trace as I added a record:
> > > > > <methodName>GetaNewUD10</methodName>
> > > > > <methodName>GetByID</methodName>
> > > > > <methodName>Update</methodName>
> > > > > <methodName>GetRowsKeepIdleTime</methodName>
> > > > > --- In vantage@yahoogroups.com, "cooner_55421" <cooner_55421@> wrote:
> > > > > > Hi Jose,
> > > > > > I'd like to do this on UD10Form.
> > > > > > When I use "File, New" from the menu.
> > > > > > I was lucky and found code for auto-assigning the next number
> > > available
> > > > > (a tech tip example for UD03). It works nice.
> > > > > > Now, a "File, New" button would really be better than having to use
> > > the
> > > > > menu.
> > > > > > Thanks
> > > > > > > Can you be more specific....
> > > > > > > A File new What to which form?
> > > > > > > *Jose C Gomez*
> > > > > > > *Software Engineer*
> > > > > > > E: jose@
> > > > > > > On Tue, Apr 12, 2011 at 1:55 PM, cooner_55421 <cooner_55421@
> > > >wrote:
> > > > > > > > Hi,
> > > > > > > > Just wondering if anybody has an example for adding a "file, new"
> > > > > button to
> > > > > > > > a form?
> > > > > > > > Thanks
> > > > > > > [Non-text portions of this message have been removed]
*Jose C Gomez*
*Software Engineer*
E: jose@...
On Tue, Apr 12, 2011 at 1:55 PM, cooner_55421 <cooner_55421@...>wrote:
> Hi,
> Just wondering if anybody has an example for adding a "file, new" button to
> a form?
> Thanks
something like
int rowCnt = 0;
int lineNum;
lineNum = rowCnt;
while (!goodIdx)
System.Data.DataRow[] drs = oTrans_adapter.UD10Data.UD10.Select("Key5 = '"
if (drs.Length > 0)
lineNum++;
else
goodIdx = true;
*Jose C Gomez*
*Software Engineer*
E: jose@...
On Tue, Apr 12, 2011 at 2:30 PM, cooner_55421 <cooner_55421@...>wrote:
> BTW..
> > Hi Jose,
> > I was lucky and found code for auto-assigning the next number available
> > Now, a "File, New" button would really be better than having to use the
> menu.
> > Thanks
> > > *Jose C Gomez*
> > > *Software Engineer*
> > > E: jose@
> > > On Tue, Apr 12, 2011 at 1:55 PM, cooner_55421 <cooner_55421@>wrote:
> > > > Hi,
> button to
> > > > a form?
> > > > Thanks
*Jose C Gomez*
*Software Engineer*
E: jose@...
> BTW...
> > something like
> > int rowCnt = 0;
> > int lineNum;
> > lineNum = rowCnt;
> > while (!goodIdx)
> > if (drs.Length > 0)
> > lineNum++;
> > else
> > goodIdx = true;
> > *Jose C Gomez*
> > *Software Engineer*
> > E: jose@...
> > > BTW..
> > > > Hi Jose,
> available
> the
> > > menu.
> > > > Thanks
> > > > > *Jose C Gomez*
> > > > > *Software Engineer*
> > > > > E: jose@
> >wrote:
> > > > > > Hi,
> > > button to
> > > > > > a form?
> > > > > > Thanks
