Hey,
I could surely use some assistance, a common occurrence.
I’m building a part mom in a BPM off quote entry. It all looks good to a point.
I can check out the revision (it has an alt method, so checks out the revision and the alt method).
Adding operations looks okay.
At this point (after the BPM finishes) I can go to the Engineering Workbench and call up the group. I have revisions and operations, and I can approve and check in.
But if I try to use the BO to check in I get:
Server Side Exception
BPM runtime caught an unexpected exception of 'NullReferenceException' type.
See more info in the Inner Exception section of Exception Details.
Error Detail
Description: BPM runtime caught an unexpected exception of 'NullReferenceException' type.
Program: Epicor.System.dll
Method: GetObjectSetCache
Line Number: 354
Column Number: 13
Original Exception Type: NullReferenceException
Client Stack Trace
at Epicor.ServiceModel.Channels.ImplBase`1.ShouldRethrowNonRetryableException(Exception ex, DataSet[] dataSets)
at Erp.Proxy.BO.QuoteImpl.Update(QuoteDataSet ds)
at Erp.Adapters.QuoteAdapter.OnUpdate()
at Ice.Lib.Framework.EpiBaseAdapter.Update()
at Erp.UI.App.QuoteEntry.Transaction.Update()
Inner Exception
Object reference not set to an instance of an object.
I swear the inputs to the method look correct (and agree with the EWB trace):
string ipGroupID = groupID;
string ipPartNum = parentPartNum;
string ipRevisionNum = parentRevisionNum;
string ipAltMethod = parentAltMethod;
DateTime? ipAsOfDate = DateTime.Today;
bool ipCompleteTree = false;
bool ipValidPassword = false;
bool ipReturn = true;
bool ipGetDatasetForTree = true;
bool ipUseMethodForParts = false;
string ipAuditText = "ECO Group JT Joe's Group";
string opMessage = "";
string opResultString = "";
this.PublishInfoMessage("(ipGroupID, ipPartNum, ipRevisionNum, ipAltMethod, ipAsOfDate, ipCompleteTree, ipReturn, ipGetDatasetForTree, ipUseMethodForParts, ipValidPassword, out opResultString): " + ipGroupID + " " + ipPartNum + " " + ipRevisionNum + " " + ipAltMethod + " " + ipAsOfDate + " " + ipCompleteTree + " " + ipReturn + " " + ipGetDatasetForTree + " " + ipUseMethodForParts + " " + ipValidPassword + " " + opResultString, Ice.Common.BusinessObjectMessageType.Information, Ice.Bpm.InfoMessageDisplayMode.Individual, "", "");
dsEngWorkbench =
engWorkBench.CheckIn(ipGroupID, ipPartNum, ipRevisionNum, ipAltMethod, ipAsOfDate, ipCompleteTree, ipValidPassword, ipReturn, ipGetDatasetForTree, ipUseMethodForParts, ipAuditText, out opMessage);
Note: Part of the CheckIn method seems to work. If I don’t first approve the revisions by marking them approved in ECORev and updating them I get this message:
Business Layer Exception
The Revision cannot be checked in until all Alternate Methods have been approved.
Error Detail
Description: The Revision cannot be checked in until all Alternate Methods have been approved.
Program: Erp.Services.BO.EngWorkBench.dll
Method: CheckIn
Line Number: 8089
Column Number: 5
Table: ECORev
Client Stack Trace
Anyone have an idea?
Joe
