Build SSRS
A while back I made an error when upgrading and totally messed up my reports. Epicor helped get me back on track and now I am working on trying to create new reports. Problem is, it will not launch from the Designer. Called Epicor and was told that this issue is known for my version and was fixed in 10.1.500. For now, just bring it up manually. But how do you create an new SSRS report based on a query you wrote, manually?
If you wanted the report to be based off of an external datasource, you could follow this approach:
Otherwise, you can redo the query as a native BAQ, and just the native BAQ Report functionality–there is an embedded education course on it and info in the ICE Tools Guide/Application help.
