Broke old versions installing new version
I am trying to update 1 environment on our server to kinetic for testing. We have others instances on the server as well and in the process, I broke the other test environments. below is the error I get when i try to connect to the App server
System.Net.Http.HttpRequestException: An error occurred while sending the request. —> System.Net.WebException: The underlying connection was closed: Could not establish trust relationship for the SSL/TLS secure channel. —> System.Security.Authentication.AuthenticationException: The remote certificate is invalid according to the validation procedure.
at System.Net.TlsStream.EndWrite(IAsyncResult asyncResult)
at System.Net.PooledStream.EndWrite(IAsyncResult asyncResult)
at System.Net.ConnectStream.WriteHeadersCallback(IAsyncResult ar)
— End of inner exception stack trace —
at System.Net.HttpWebRequest.EndGetRequestStream(IAsyncResult asyncResult, TransportContext& context)
at System.Net.Http.HttpClientHandler.GetRequestStreamCallback(IAsyncResult ar)
at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task)
at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)
at Microsoft.Extensions.Http.Logging.LoggingHttpMessageHandler.d__5.MoveNext()
— End of stack trace from previous location where exception was thrown —
at Microsoft.Extensions.Http.Logging.LoggingScopeHttpMessageHandler.d__5.MoveNext()
at Ice.Cloud.ProxyBase`1.d__60.MoveNext()
at Epicor.Utilities.AsyncHelper.RunSync[TResult](Func`1 method)
at Ice.Cloud.ProxyBase`1.Execute(String methodName, RestValueSerializerBase serializer, ProxyValuesIn valuesIn, ProxyValuesOut valuesOut)
at Ice.Cloud.ProxyBase`1.<>c__DisplayClass58_0.b__0(Context _)
at Polly.Policy`1.<>c__DisplayClass32_0.b__0(Context ctx, CancellationToken ct)
at Polly.Retry.RetryEngine.Implementation[TResult](Func3 action, Context context, CancellationToken cancellationToken, IEnumerable1 shouldRetryExceptionPredicates, IEnumerable1 shouldRetryResultPredicates, Func1 policyStateFactory)
at Polly.RetryTResultSyntax.<>c__DisplayClass12_01.<WaitAndRetry>b__0(Func3 action, Context context, CancellationToken cancellationToken)
at Polly.Policy1.ExecuteInternal(Func3 action, Context context, CancellationToken cancellationToken)
at Polly.Policy1.Execute(Func3 action, Context context, CancellationToken cancellationToken)
at Polly.Policy1.Execute(Func2 action, Context context)
at Ice.Cloud.ProxyBase`1.CallWithCommunicationFailureRetry(String methodName, ProxyValuesIn valuesIn, ProxyValuesOut valuesOut, RestRpcValueSerializer serializer)
at Ice.Cloud.ProxyBase`1.CallWithMultistepBpmHandling(String methodName, ProxyValuesIn valuesIn, ProxyValuesOut valuesOut, Boolean useSparseCopy)
at Ice.Cloud.ProxyBase`1.Call(String methodName, ProxyValuesIn valuesIn, ProxyValuesOut valuesOut, Boolean useSparseCopy)
at Ice.Proxy.BO.UserFileImpl.GetUserFile()
at Epicor.Mfg.Administration.ServerManagement.ApplicationServerManager.Forms.NewSessionForm.BackgroundWorker_DoWork(Object sender, DoWorkEventArgs e)
at System.ComponentModel.BackgroundWorker.OnDoWork(DoWorkEventArgs e)
at System.ComponentModel.BackgroundWorker.WorkerThreadStart(Object argument)
Fixed that issue. now I am getting this
System.Exception: Unable to find server config or template file in the server directory.
at SetupEnvironment.Steps.ConfigureServerConfig.CopyFromTemplate(String configFileName)
at SetupEnvironment.Steps.ConfigureServerConfig.InnerRun()
at SetupEnvironment.StepBase.Run()
Hello Matthew. How did you fix the first issue? I am attempting an upgrade from E10.2.600 to Kinetic 2022.1 and received the same error after creating the App Server.
Thanks for any guidance,
Kelly
I’m assuming you chose to create a self-signed certificate.
This post might be of some help:
