Good Day:
When we switch from M2K to E9, we are going to make our BOM's
multi-level so we can issue groups of part with different dates. I note,
from below, that V8 has "Sequence #" - I assume E9 will also.
In M2K, we used the "Reference designator" field in BOM (PS) file to
store a "section" number, so when sorted BOM is in 'section" order.
I think we could leave the bill flat and do ISSUES based on "Section
(Sequence#).
Has anyone done anything like that? Or, more broadly, if you have a
BOM with 3,000 parts and 40 sections, how do you get 'sections' to be
required, and to pull, on different dates?
Note: our sections are NOT sub-assemblies that get built and
stocked.
We want desperately to avoid having 40 WO's
len.hartka@...
Leonard C. Hartka, IT Director\ERP Manager
Sun Automation Group
66 Loveton Circle
Sparks, Md. 21152
410-329-3560 ext. 120
410-329-3564 FAX
443-255-7192 Work Cell
len.hartka@...
www.Sunautomation.com <
http://www.sunautomation.com/>
vantage@yahoogroups.com [mailto:
vantage@yahoogroups.com] On Behalf
Of Late, Travis
Sent: Tuesday, December 22, 2009 10:45 AM
To:
Subject: RE: [Vantage] BOM and Supplier Report
The fields that I'm looking for would be:
Level, Type, Sequence, Part Number, Revision, Description, Qty, IUM,
Price, Supplier.
Hoping do have parameters set as a Job number and a Part number. Is this
possible?
vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>
[mailto:
vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> ] On
Behalf
Of IT Support
Sent: Tuesday, December 22, 2009 9:14 AM
To:
Travis,
Can you be a little more specific with what you need on the report,
field wise?
I have several reports that may be what you're looking for, but I want
to send the closest ones possible,
Ron Flynn
Cubic Designs, Inc.
CUSTOM MEZZANINE SYSTEMS
www.cubicdesigns.com
262.789.1966
262.789.1970 fax
[mailto:
Behalf
Of Late, Travis
Sent: Tuesday, December 22, 2009 8:20 AM
To:
Subject: [Vantage] BOM and Supplier Report
I'm looking to create a report that displays just like and indented BOM
Listing report. The only information that I need to add is the supplier
for the particular part. Anyone have a report similar to this one
created? I know the BOM Listing report in Vantage is progress based ,
which makes it impossible for me to modify. Looks like Crystal is the
way to go. Any help is appreciated.
Travis Late
ERP Project Manager
M-B Companies, Inc
1200 Park Street
Chilton, WI 53014
Phone: 920-898-1560 Ext.152
Cell: 920-960-0062
Email:
tlate@... <mailto:tlate%40m-bco.com>
<mailto:
<mailto:tlate%40m-bco.com> >
M-B Companies Confidentiality Notice:
This message is being sent by M-B Companies. It is intended exclusively
for
the individuals and entities to which it is addressed. This
communication,
including any attachments, may contain information that is proprietary,
privileged and confidential if you are not the named addressee; you are
not
authorized to read,print,retain copy or disseminate this message or any
part
of it.If you have received this message in error, please notify the
sender
immediately by email.
for
communication,
not
part
sender
This e-mail and any attachments may contain proprietary and/or confidential information. If you are not the intended recipient, please notify the sender immediately by reply e-mail or at 410-472-2900 and then delete the message without using, disseminating, or copying this message or any portion thereof. With e-mail communications you are urged to protect against viruses.
